From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of Les Newell
Sent: Monday, March 11, 2013 08:19
Subject: Re: [Homebrew_PCBs] PCB Milling bits
Just grinding a point then cutting off half the bit won't work as the
cutter would have no clearance angle. You would get a really rough cut
and quite likely snap the tip off the cutter. Grinding the flat is a
pain as you need to remove a relatively large amount of material and you
need to be quite accurate. This page gives some great info
<http://www.antaresinc.net/FactAnatomy.html>. Note that you need a
fairly fine diamond wheel to get a good enough finish. If you don't
already have a wheel and a suitable grinder it is far cheaper to buy the
cutters than make them. Considering the price of new cutters on eBay it
is not really worth the effort to make them in my opinion.
If you have a suitable diamond wheel it is worth resharpening cutters as
they wear out quite quickly. My grinding fixture is really simple but
works well. I have a mount that has a 1/8" hole bored in it. This is
bolted to my tool and cutter grinder and supports the cutter. I then
clamp a collet to the cutter. The collet has an arm sticking out of it
which I use to rotate the cutter. I have a stop that locates on the arm
and prevents me from rotating the cutter too far. The position of this
stop controls the clearance angle. Once set up it takes about a minute
to sharpen a cutter.
Les
On 09/03/2013 08:16, Boman33 wrote:
> Recently I remember an article about using broken PCB carbide drilling
bits
> to make V tipped router bits. Basically grind the desired angle and then
> grind off half the bit. There was a careful procedure to allow accurate
and
> good performance.
> I have googled, hunted in the email lists, and my own computer without
> success.
> Any suggestions where I can find it?
