Homebrew PCBs
Etching Brass
Etching Brass
2013-08-23 by RogerRetro
Clark,
I have used the Pulsar toner transfer quite successfully on .005 & .010 brass sheet, and yes, there is some undercutting. It will take a bit of dimensional trial and error if you need high precision.
Roger
Re: [Homebrew_PCBs] Etching Brass
2013-08-23 by Misc Clark
Hi Roger...thanks for the reply! Do you have opinion about whether the
Pulsar process would be different, better, cheaper, or easier than the
waxed-paper-from-China toner-transfer method?
Clark
On Fri, Aug 23, 2013 at 12:57 PM, RogerRetro <Roger.Blair@...>wrote:
> Clark,
> Regards,
> Roger
Re: Etching Brass
2013-08-23 by cunningfellow
> Clark wrote:
> <SNIP>
> cheaper, or easier than the waxed-paper-
Brass etching is very on topic for here.
You use brass shims to apply solder paste.
Pulsar process will be better as you also
have the TRF Green layer to help block out
pinholes.  The chinese wax/plastic paper
will only have a bare toner layer.
If you want to etch brass I recommend using
photo.  Much less likely to have unsightly
pinholes come through somewhere you wanted
it all shinny and clean.
I have etched a LOT of brass in my time and
I can def. say that Pulsar with TRF is a
giant step up from bare toner and then
photo is a leap in quality again.
Re[2]: [Homebrew_PCBs] Etching Brass
2013-08-24 by Roger Blair
Hi Clark,
I haven't yet tried the process with the "China" paper, whatever it
is... I did get some to try when I have time (which won't be soon, due
to other projects). It appears somewhat similar to the backing on
contact paper.
I have on occasion used plastic model paint to touchup pinholes if they
apear too big for the green film to cover...  many decisions are
variable based on the overall size and geometry of the parts to be
etched. The parts I was working with were small, roughly 1/4x1/2 inch or
so in size with holes and tabs... With care I held to a couple of
thousanths overall tolerance. Its been a few years now since I've done
anything along these lines...
Roger
------ Original Message ------
Sent: 8/23/2013 10:36:37 AM
Subject: Re: [Homebrew_PCBs] Etching Brass
>Clark
>>  Clark,
>>.010
>>of
>>  Regards,
>>  Roger
>Be sure to visit the group home and check for new Links, Files, and
>Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
