Expo Drill Stand 14211
2013-09-03 by <v321uk@...>
Does anyone here have experience in using an Expo 14211 mini drill stand? Intended use occasional PCB making. Is there much 'run out' ? Would you recommend it ? I tried searching the group but cant see a text search only a message number search. Thanks, John G3UGY
2013-09-05 by <arvidj@...>
It appears to be the same as a "PZ541 Vertical Drill Stand".
I do not have either one. Just wanted to pass along an additional set of 'tokens' to Google for information.
Here are some other links that I ran across looking for a solution. Note that this is not an endorsement of any of them. Simply trying to share what little knowledge I have.
Someone who seems to have had experience with the style you were looking at:
http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/134856-pcb-drill-press-ideas-revisited.html
Other options that I have found:
http://www.vanda-layindustries.com/html/drill_press_plus.html
http://www.megauk.com/pcb_drilling_machines.php
http://shop.prox-tech.com/p/micromot-drill-stand-mb-200
http://www.proxxon-direct.com/acatalog/micromot_drill_stand_mb_140s.html
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_26711_-1
Arvid
--- In homebrew_pcbs@yahoogroups.com, <v321uk@...> wrote:Does anyone here have experience in using an Expo 14211 mini drill stand?
Thanks, John G3UGY
2013-09-05 by John
Here are some comments I found on the PZ541 http://www.electro-tech-online.com/general-electronics-chat/122682-time-new-drill-stand.html
From: arvidj@... Sent: Thursday, September 05, 2013 4:50 PM To: Homebrew_PCBs@yahoogroups.com Subject: [Homebrew_PCBs] RE: Expo Drill Stand 14211 It appears to be the same as a "PZ541 Vertical Drill Stand". I do not have either one. Just wanted to pass along an additional set of 'tokens' to Google for information. --- In homebrew_pcbs@yahoogroups.com, <v321uk@...> wrote: Does anyone here have experience in using an Expo 14211 mini drill stand? Intended use occasional PCB making. Is there much 'run out' ? Would you recommend it ? I tried searching the group but cant see a text search only a message number search. Thanks, John G3UGY
2013-09-28 by <arvidj@...>
As a follow up to this thread ...
I ordered the Jameco Drill Stand Works with Mini Drill (Part 26702) ...
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=26711
Note that I did not order the Miniature Drill 12000 RPM associated with it ...
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=26702&catalogId=10001&CID=MERCH
because I have a Dremel 4000 and was hoping to use that.
Regretfully the stand is not capable of supporting the Dremel 4000 securely. The Dremel 4000 is just too big and heavy.
I am not sure if I will bother to get the "correct" motor. While I will admit that for $28 plus shipping the stand is reasonably solid I feel the term "will not be solid enough even with the smaller motor" applies.
I
2013-09-28 by John
That's the one I bought 26711. Small but takes my Expo mini drill. With the three shafts run out is minimal, fine for my needs. John
From: arvidj@... Sent: Saturday, September 28, 2013 2:38 PM To: Homebrew_PCBs@yahoogroups.com Subject: [Homebrew_PCBs] RE: Expo Drill Stand 14211 As a follow up to this thread ... I ordered the Jameco Drill Stand Works with Mini Drill (Part 26702) ... http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=26711 Note that I did not order the Miniature Drill 12000 RPM associated with it ... http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=26702&catalogId=10001&CID=MERCH because I have a Dremel 4000 and was hoping to use that. Regretfully the stand is not capable of supporting the Dremel 4000 securely. The Dremel 4000 is just too big and heavy. I am not sure if I will bother to get the "correct" motor. While I will admit that for $28 plus shipping the stand is reasonably solid I feel the term "will not be solid enough even with the smaller motor" applies. ---In homebrew_pcbs@yahoogroups.com, <v321uk@...> wrote: Here are some comments I found on the PZ541 http://www.electro-tech-online.com/general-electronics-chat/122682-time-new-drill-stand.html From: arvidj@... Sent: Thursday, September 05, 2013 4:50 PM To: Homebrew_PCBs@yahoogroups.com Subject: [Homebrew_PCBs] RE: Expo Drill Stand 14211 It appears to be the same as a "PZ541 Vertical Drill Stand". I do not have either one. Just wanted to pass along an additional set of 'tokens' to Google for information. --- In homebrew_pcbs@yahoogroups.com, <v321uk@...> wrote: Does anyone here have experience in using an Expo 14211 mini drill stand? Intended use occasional PCB making. Is there much 'run out' ? Would you recommend it ? I tried searching the group but cant see a text search only a message number search. Thanks, John G3UGY
2013-09-29 by Jim
--- In Homebrew_PCBs@yahoogroups.com, <v321uk@...> wrote: > > Does anyone here have experience in using an Expo 14211 mini drill stand? > > Intended use occasional PCB making. > > Is there much 'run out' ? > > Would you recommend it ? > I tried searching the group but cant see a text search only a message number search. > Thanks, John G3UGY > Just to add to this discussion: http://www.flickr.com/photos/wb8nbs/9187175381/ I got this small cast iron drill press at a flea market. Added the stand and belt. No information on the original use of the device though I suspect it was part of some larger machine. It is very accurate, but only about 3000 rpm.
