Punching small PCBs, Issues using thin PCB material?
2014-05-11 by Peter Johansson
I have a project idea that would require hundreds (possibly thousands) of very small PCBs, each one being a circle approx. 1/2 inch in diameter. Does anyone know if it would be possible to punch them out of thin FR4 with a punch press? That is, use the material that is normally discarded when punching out a hole. Aside from that, what (if any) are the issues with using thin (0.010" - 0.030") PCB material in general? -p.
2014-05-11 by Brad Thompson
On 5/10/2014 8:31 PM, Peter Johansson rockets4kids@... [Homebrew_PCBs] wrote: > > I have a project idea that would require hundreds (possibly thousands) > of very small PCBs, each one being a circle approx. 1/2 inch in > diameter. Does anyone know if it would be possible to punch them out > of thin FR4 with a punch press? That is, use the material that is > normally discarded when punching out a hole. > > Aside from that, what (if any) are the issues with using thin (0.010" > - 0.030") PCB material in general? > > Hello-- If your board has a ground plane (i.e., is two-sided) and is made of thin stock, the punching operation can stretch copper around the board's edges and thus cause possible creepage problems. This can be a problem if traces on the board's top side go all the way to the edges. 73-- Brad AA1IP --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com
2014-05-11 by Boman33
That should work fine. Just do not have any runners next to the edge. I have used 10mil and thinner FR4 making PCB that were 3 x 3mm. I laser cut the PCB for the very small PCBs. Bertho
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] Sent: Saturday, May 10, 2014 20:31 To: Homebrew_PCBs@yahoogroups.com Subject: [Homebrew_PCBs] Punching small PCBs, Issues using thin PCB material? I have a project idea that would require hundreds (possibly thousands) of very small PCBs, each one being a circle approx. 1/2 inch in diameter. Does anyone know if it would be possible to punch them out of thin FR4 with a punch press? That is, use the material that is normally discarded when punching out a hole. Aside from that, what (if any) are the issues with using thin (0.010" - 0.030") PCB material in general? -p.
2014-05-11 by Jean-Paul Louis
Peter, You’re going to wear your punch very fast as FR4 is loaded with glass which is very abrasive. Unless you can have a very high resistance punch which would cost hundreds of dollars. I used a punch press to cut boards in a previous job. The wear of the punches and dies were very costly. so we replaced the whole process by a router. But that was for 0.062” FR4. You have also to make sure that there is no copper in the cut area. Jean-Paul AC9GH
On May 10, 2014, at 8:31 PM, Peter Johansson rockets4kids@gmail.com [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote: > I have a project idea that would require hundreds (possibly thousands) > of very small PCBs, each one being a circle approx. 1/2 inch in > diameter. Does anyone know if it would be possible to punch them out > of thin FR4 with a punch press? That is, use the material that is > normally discarded when punching out a hole. > > Aside from that, what (if any) are the issues with using thin (0.010" > - 0.030") PCB material in general? > > -p. > >
2014-05-11 by Roger Blair
You might try a 5/8"OD diamond thin wall core drill; it may be close enough to 12"ID and I think the FR4 would clear any copper buildup, and likely wear well. Just a thought... Roger On 5/10/2014 7:10 PM, Jean-Paul Louis louijp@... [Homebrew_PCBs] wrote:
> Peter, > > You\ufffdre going to wear your punch very fast as FR4 is loaded with glass which is very abrasive. > Unless you can have a very high resistance punch which would cost hundreds of dollars. > > I used a punch press to cut boards in a previous job. The wear of the punches and dies were very costly. > so we replaced the whole process by a router. But that was for 0.062\ufffd FR4. You have also to make sure that > there is no copper in the cut area. > > Jean-Paul > AC9GH > > > On May 10, 2014, at 8:31 PM, Peter Johansson rockets4kids@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote: > >> I have a project idea that would require hundreds (possibly thousands) >> of very small PCBs, each one being a circle approx. 1/2 inch in >> diameter. Does anyone know if it would be possible to punch them out >> of thin FR4 with a punch press? That is, use the material that is >> normally discarded when punching out a hole. >> >> Aside from that, what (if any) are the issues with using thin (0.010" >> - 0.030") PCB material in general? >> >> -p. >> >> > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo Groups Links > > > >
On Sat, May 10, 2014 at 10:10 PM, Jean-Paul Louis louijp@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote: > You’re going to wear your punch very fast as FR4 is loaded with glass which is very abrasive. > Unless you can have a very high resistance punch which would cost hundreds of dollars. > I used a punch press to cut boards in a previous job. The wear of the punches and dies were very costly. This is my concern as well. This is part of the reason I want to go with as thin a board as I can get away with. Do you recall how many cuts you were getting per punch/die set? > so we replaced the whole process by a router. But that was for 0.062” FR4. That is my other option. I am looking at something on the order of several hundred boards for my prototype run, and if I go into production beyond that I will probably have the boards professionally made. There are still a few unknowns, and I would prefer to work them out making the PCBs myself before setting up a job. Speaking of which, does anyone know a board house that is friendly towards lots of (cutting) routing? > You have also to make sure that there is no copper in the cut area. Yes, I had figured that the punch could damage any traces along the cut. That shouldn't be a problem. -p.
2014-05-11 by Stefan Trethan
Regardless of the cutting method used there should never be any copper near the cut line. Mind that round hand operated punches typically have a pip in the center to locate a center punch mark. You may have to grind that off or maybe you can have a small hole there and use it. Some punches heavily deform the disc ( to make it smaller and fit through the die easier), those may not be suitable. I have seen small circular PCBs manufactured, and they were routed. There are good reasons, routing is a standard manufacturing step the commercial PCB supplier can do. Also leaving the discs connected via breakout tabs means the whole panel can be processed for machine assembly and testing. ST On Sun, May 11, 2014 at 8:32 AM, Peter Johansson rockets4kids@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> On Sat, May 10, 2014 at 10:10 PM, Jean-Paul Louis louijp@... > [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote: > >> You’re going to wear your punch very fast as FR4 is loaded with glass which is very abrasive. >> Unless you can have a very high resistance punch which would cost hundreds of dollars. >> I used a punch press to cut boards in a previous job. The wear of the punches and dies were very costly. > > This is my concern as well. This is part of the reason I want to go > with as thin a board as I can get away with. Do you recall how many > cuts you were getting per punch/die set? > >> so we replaced the whole process by a router. But that was for 0.062” FR4. > > That is my other option. I am looking at something on the order of > several hundred boards for my prototype run, and if I go into > production beyond that I will probably have the boards professionally > made. There are still a few unknowns, and I would prefer to work them > out making the PCBs myself before setting up a job. > > Speaking of which, does anyone know a board house that is friendly > towards lots of (cutting) routing? > >> You have also to make sure that there is no copper in the cut area. > > Yes, I had figured that the punch could damage any traces along the > cut. That shouldn't be a problem. > > -p. > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo Groups Links > > >
2014-05-11 by Charles R Patton
A comment on the question of "... what (if any) are the issues with using thin (0.010" - 0.030") PCB material in general?" I did a run of an SMT bds about 2.5": x 2.5" in 0.010" thick material and regretted it. It was just too flimsy and if you intend to do the core drill idea I'd be suspicious about possible tearing. I'm now using 0.023" thick material and think it is quite satisfactory and I suspect that it would be fine in a 1/2" disk. The 0.023" is about as stiff as K&S 0.015 SS shim. This shim is 430 SS in a dead soft condition. I mention the K&S shim as it is often available in US craft and hardware stores if you're trying to get a feel for the stiffness. Regards, Charles R. Patton On 5/10/2014 10:50 PM, Roger Blair Roger.Blair@... [Homebrew_PCBs] wrote:
> You might try a 5/8"OD diamond thin wall core drill; it may be close > enough to 12"ID and I think the FR4 would clear any copper buildup, and > likely wear well. > Just a thought... > Roger > On 5/10/2014 7:10 PM, Jean-Paul Louis louijp@... [Homebrew_PCBs] > wrote: >> Peter, >> >> You\ufffdre going to wear your punch very fast as FR4 is loaded with glass which is very abrasive. >> Unless you can have a very high resistance punch which would cost hundreds of dollars. >> >> I used a punch press to cut boards in a previous job. The wear of the punches and dies were very costly. >> so we replaced the whole process by a router. But that was for 0.062\ufffd FR4. You have also to make sure that >> there is no copper in the cut area. >> >> Jean-Paul >> AC9GH >> >> >> On May 10, 2014, at 8:31 PM, Peter Johansson rockets4kids@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote: >> >>> I have a project idea that would require hundreds (possibly thousands) >>> of very small PCBs, each one being a circle approx. 1/2 inch in >>> diameter. Does anyone know if it would be possible to punch them out >>> of thin FR4 with a punch press? That is, use the material that is >>> normally discarded when punching out a hole. >>> >>> Aside from that, what (if any) are the issues with using thin (0.010" >>> - 0.030") PCB material in general? >>> >>> -p. >>> >>> >> >> ------------------------------------ >> >> Be sure to visit the group home and check for new Links, Files, and Photos: >> http://groups.yahoo.com/group/Homebrew_PCBsYahoo Groups Links >> >> >> >> > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo Groups Links > > >
On Sun, May 11, 2014 at 2:23 PM, Charles R Patton charles.r.patton@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote: > A comment on the question of "... what (if any) are the issues with > using thin (0.010" - 0.030") PCB material in general?" I did a run of > an SMT bds about 2.5": x 2.5" in 0.010" thick material and regretted > it. It was just too flimsy and if you intend to do the core drill idea > I'd be suspicious about possible tearing. I'm now using 0.023" thick > material and think it is quite satisfactory and I suspect that it would > be fine in a 1/2" disk. Thanks for the heads up. I found some cheap single sheets of 0.010" and 0.026" at electronics goldmine and I am currently awaiting delivery on those for testing. I did price out diamond core drills and gacked at the $50 - $150 price tag. Between the price, the dust issues, and the potential for the cut-outs to get caught up in the bit I am going to keep this as a last resort. -p.
2014-05-13 by Paul Alciatore
Do you really need a fiberglass backed board? There are other materials available that would allow punching with far less problems with punch wear. I would talk to a PC board manufacturer. I am sure they can make some good suggestions.
2014-05-13 by Peter Johansson
On Tue, May 13, 2014 at 7:22 PM, Paul Alciatore palciatore@... wrote: > Do you really need a fiberglass backed board? There are other > materials available that would allow punching with far less problems > with punch wear. I don't need fiberglass, but I have not found a source for thin, non-fiberglass board > I would talk to a PC board manufacturer. I am sure they can make some > good suggestions. At the suggestion of others I have investigated this. It turns out that routing out all these discs is not going to be nearly as expensive as I had thought, and that is now the route I am going to take. -p.
2014-05-15 by palciatore@...
> Do you really need a fiberglass backed board? There are otherI don't need fiberglass, but I have not found a source for thin,
> with punch wear.
> I would talk to a PC board manufacturer. I am sure they can make someAt the suggestion of others I have investigated this. It turns out
> good suggestions.
