Homebrew PCBs
A short story of the Selenium Photo-sensitive Drum.
2014-12-15 by howard.chester@...
This is to reference to the discussion about LASER Printer build
In the seventies, small Company offices saw the birth of the Photocopier.
These used a Selenium coated drum, charged up to about 3,000V(3Kv) by a
Corona wire near the drum. The rotating drum was exposed to a thin line
of light produced by a set of scanning mirrors and constant focus lenses.
The areas exposed to light areas in the image, discharges the 3Kv charge
on the charged drum. This is called the Latent Image. The drum is immersed
In a liquid mixture of developer and toner, whereby the toner is attracted to
Charged (un-exposed) areas on the drum. The drum now passes a 1,000 (1Kv) transfer corona wire behind the paper, transferring the latent image to the surface of the paper. The final stage is to evaporate the clear developer and fuse theToner, in the fusing heaters.
A major improvement was to add Arsenic to the Selenium Drum, improving
theDrum sensitive to blue colours (this is the reason that forms and notes
were required to be filled-in and signed with black ink as a Blue signature "dissapears"!).
The next major improvement was the "Dry Copier", eliminating the
Stinky liquid developer. This of course led on to the modern LASER copier, this
still uses the Selenium / Arsenic drum but digital image detection, processing
and LASER drum scanning is used to produce the latent image.
This point also highlights the Drums lack of sensitivity to Blue / UV LASERS
A few tips when handling the drum
1) Selenium is EXTREMELY TOXIC!!!. Handle with gloves and mask.
Selenium in a heavy Metal and as such accumulates in the body, similar
to Mercury. Effects may only become apparent Years later.
2) The drum surface is damaged by the sweat and oil from fingerprints,
Use gloves.
3) In my years as a Photo-Copier Tech, small scratches on the drum surface
were removed with a "steel-wool" type cotton based copper cleaner. The
Drum is lightly polished in an up and down motion from top to bottom.
Rinse with IPA(Iso-Propal Alcohol).
(DO NOT USE STEEL WOOL! this is for descriptive purpose only). This
Process could only used 3 times before replacing the drum.
I hope these notes prove useful and informative to all,
Chester
Re: [Homebrew_PCBs] A short story of the Selenium Photo-sensitive Drum.
2014-12-16 by Slavko Kocjancic
Hello...
Producting PCB this way takes even longer time that a coating PCB with
photoresist and imaging with laser. And I can confirm that photoresist
and laser works very nice with some care down to 4mil track/4mil space
without some big problems. I like to see some other methods that use
less time ....
Slavko.
2014-12-16 by Mark Lerman
Less time, perhaps not 5 mil, but close:
<http://www.instructables.com/id/Modification-of-the-Lexmark-E260-for-Direct-Laser--1/>
Mark
At 03:37 AM 12/16/2014, you wrote:
>Hello...
>less time ....
>Slavko.
>Posted by: Slavko Kocjancic <eslavko@...>
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBs
>Yahoo Groups Links
On 16. 12. 2014 13:52, Mark Lerman mlerman@... [Homebrew_PCBs]
> Mark
Choosen printer is not available here on cheap. Nor the toner/drum. I
sniffing around Brother HL22xx series but seems that even removing fuser
unit dissable printer to print. There are two thermistors on unit and
just simple tampering with correct thermistor for "hot" doesn't work.
Seems that temperature controll throw error if thermistors doesn't
change resistance when lamp is on or off...
2014-12-16 by Mark
I'm pretty sure I once experimented with Brother printers and was able to get it to work without the fuser. I guess one way you could do it is to use a datalogger to see what happens with the thermistors and then emulate it with a microprocessor. I believe it was a Brother printer that I once fed a piece of .007 copperclad through and got a perfect print, perfectly fused as it passed through the fuser. I don't believe I ever got that to work with anything other than a Brother.
Mark
>From: "Slavko Kocjancic eslavko@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
>Sent: Dec 16, 2014 8:06 AM
>To: Homebrew_PCBs@yahoogroups.com
>Subject: Re: [Homebrew_PCBs] A short story of the Selenium Photo-sensitive Drum.
>> Mark
>Yahoo Groups Links
