Homebrew PCBs
Cold toner transfer FAILURE
2016-10-04 by alan00463@...
Tried the "cold toner transfer" process today using what I had
at home, acetone and 80-proof vodka (40% alcohol by volume) for my solvent.
Printed the PCB artwork on standard, white, office paper using my HP Laserjet. Using the 8:3 mix and didn't get any transfer to the copper.
So I dabbed the solvent onto the other toner patterns on the paper
and let it set half an hour before I tried rubbing it off again. Still wouldn't lift off the paper. D'OH! I forgot to print it onto something slippery. So I printed four patterns on Oracal 651 vinyl for another go at it.
Did everything according to the video, but the part where the paper and plastic are supposed to peel off the board, leaving the toner still sticking, failed miserably.
So I added another capful of acetone to the bottle, put the cap back on and shook it up, and tried again. No results.
I repeated the above two sentences about three more times. Still the toner did not detach from the Oracal. So I let put a few drops of solvent onto a different piece of Oracal with a toner pattern printed on it, and let it sit about half an hour.
Then I could rub the toner off with my thumb, but it took a good bit of pressure to lift the toner from the plastic.
This was my first try to use the "heatless" toner transfer. I think
I'll buy some 100% ethanol (grain alcohol) and try again later in the
week, unless somebody has a better idea.
Re: [Homebrew_PCBs] Cold toner transfer FAILURE
2016-10-05 by Rob
I could not get consistent results with the cold transfer method using
100% acetone and 90% rubbing alcohol.
I used an eyedropper and dropped 16 drops of alcohol and 6 drops of
acetone into a shot glass..stirred...
then wet the copper board with the mixture...then laid the artwork on
the copper face down.... the paper would saturate...then evaporate all
the liquid... then peel off.
I consistently got the image to melt off the paper but it would just rub
off the copper.... didn't stick like
heated copper took the toner.... thats when I turned to HEAT
My HEAT controller project
Definitely DID get the desired results using a $1 PIC16F628
ANYone could repeat this using the freebie PICbasic compiler at MELABS.com
which is limited to 31 lines of code..... but no worries there......mine
didn't use 20 lines of code.
http://www.learnmorsecode.com/laminator/pic/lcdexp02.jpg
http://www.learnmorsecode.com/laminator/pic/dremel60AWG.jpg
Total project cost less than $10 and will turn on a heater until it
reaches a desired temperature.
http://www.learnmorsecode.com/laminator/pic/index.html
The goal started with a laminator to do 340 F toner transfer but lead to
ANY heat control project could be  done with this circuit.....
laminator, toaster oven, hot plate, clothes dryer.... wanna bake some
cookies?
http://www.learnmorsecode.com/laminator/hotcakes.html
> solvent.
> another go at it.
2016-10-05 by Harvey Altstadter
Alan,
I use a mixture of 1:1 Acetone and Denatured Alcohol.  Both from Home
Depot. Both are inexpensive. Skip the grain alcohol, except for
celebrating your results. I run a film of the mixture onto the board,
and then put the artwork down onto the wet film. I let it sit for about
20 seconds and then press down. While I am waiting the 20 seconds, I
flood the top of the artwork with more of the mixture. At that point I
run a brayer over the board in the x and y directions for about a
minute. By that time, the board is usually pretty dry. When it is
completely dry, I drop it into the sink with some water, and let it sit
for about 15-20 minutes. I peel off what ever peels off, and then rub
the rest off with my fingers. The paper I use is the shiny, but not
coated brochure paper. I tried to use some form the Viking River cruises
catalogs we get once a week, but the paper was too thin for my printer.
The purpose of the brayer is to improve adhesion, especially at the
edges of the pattern. I bought a 6 inch one on ebay for a few dollars. I
was floored that first time I tried it this way. I had had success
without the brayer, but always had issues at the edges of the artwork.
Harvey
> solvent.
> another go at it.
2016-10-05 by Rob
Acetone... ONE to ONE?
Wow.
when I increased my acetone to anything more than the 16 drops aclcohol
to 6 drops of acetone I had
drastic resutls real quick where the toner just instantly disolved and
washed away.
WHAT IS YOUR TONER from ? Mine is HP laserjet
IS YOUR TONER FROM a BROTHER laser printer?
On 10/05/2016 12:56 AM, Harvey Altstadter hrconsult@...
> Alan,
> about 20 seconds and then press down. While I am waiting the 20
> seconds, I flood the top of the artwork with more of the mixture. At
> that point I run a brayer over the board in the x and y directions for
> about a minute. By that time, the board is usually pretty dry. When it
> is completely dry, I drop it into the sink with some water, and let it
> sit for about 15-20 minutes. I peel off what ever peels off, and then
> rub the rest off with my fingers. The paper I use is the shiny, but
> not coated brochure paper. I tried to use some form the Viking River
> cruises catalogs we get once a week, but the paper was too thin for my
> printer.  The purpose of the brayer is to improve adhesion, especially
> at the edges of the pattern. I bought a 6 inch one on ebay for a few
> dollars. I was floored that first time I tried it this way. I had had
> success without the brayer, but always had issues at the edges of the
> artwork.
> Harvey
>> solvent.
My toner is for a Brother multifunction laser printer. It is a third
party cartridge. I think the issue is similar to the one with the hot
methods, in that the process needs to be optimized for the particular
toner.  I tried various combinations of acetone and denatured alcohol
just on some printed patterns, to see what would make the toner run. It
took the 1:1 mix to really make it work. I just got a cartridge from a
different third party, and I have yet to try it. I suspect that some
experimentation will be in order.
> Wow.
> aclcohol to 6 drops of acetone I had
> washed away.
>> Alan,
>> for about a minute. By that time, the board is usually pretty dry.
>> When it is completely dry, I drop it into the sink with some water,
>> and let it sit for about 15-20 minutes. I peel off what ever peels
>> off, and then rub the rest off with my fingers. The paper I use is
>> the shiny, but not coated brochure paper. I tried to use some form
>> the Viking River cruises catalogs we get once a week, but the paper
>> was too thin for my printer.  The purpose of the brayer is to improve
>> adhesion, especially at the edges of the pattern. I bought a 6 inch
>> one on ebay for a few dollars. I was floored that first time I tried
>> it this way. I had had success without the brayer, but always had
>> Harvey
>>> solvent.
2016-10-06 by alan00463@...
Tried another transfer using ORACAL 651, using a mixture of half
acetone and half denatured alcohol Followed Harvey's directions
and burnished the artwork backside with the backside of a fork
following DuWayne. The artwork did not transfer.
Tried it again with the same mixture. This time I put the copper
clad board between two steel plates that I marked with a red Sharpie.
I squeezed them together for ten minutes using two medium C clamps.
This time about a third of the toner transfer from the artwork to
the copper clad--in the middle of the board. PARTIAL SUCCESS...
Next time, try applying pressure with a pipe clamp. Better yet,
get a 6-inch brayer. I see the brayers come in either hard rubber
or soft rubber. Which kind did you get, Harvey? I've never used one.
2016-10-07 by Cecil Bayona
Sound like you have a toner problem, some third brad toners can be
problematic. The toner not melting is your problem you need to use a
different toner or a different solvent to get that toner to melt.
> Posted by: alan00463@...
Cecil - k5nwa
http://thepartsplace.k5nwa.com/
RE: [Homebrew_PCBs] Cold toner transfer FAILURE
2016-10-07 by Andrew Volk
I haven’t tried this method, but you keep mentioning that you are using ORACAL 651.  That is a vinyl that would not let any solvent penetrate it.  It also have better adhesion for the toner.  The impression I get from everyone is that this is a method for transferring from paper.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Thursday, October 06, 2016 4:55 PM
Subject: Re: [Homebrew_PCBs] Cold toner transfer FAILURE
2016-10-07 by Harvey Altstadter
Alan,
The hard rubber brayer is the one.  Got it on ebay for a few bucks.
I really soak down the back of the paper and let it sit for a while
before I roll it. If it dries out, I put some more of the mixture on it.
Using a rounded object gave me partial results and some encouragement
when I got a partial transfer that way, mostly in the middle.  The
brayer is good because it gets the pressure across the whole board, not
just the middle.   Another thing I noticed is that some of my boards are
slightly warped.  If you observe that, either skip using the board, or
make sure you roll parallel the warp, not across it. The board needs to
be a bit larger than the circuit layout to make sure that you can roll
over the edges without running off the board close to the edge of the
artwork. I use hot glue to stick the board onto a larger wooden board
that I can keep from moving around. When I am done with the transfer,
and ready to put the board in  the water, I pop the board off the bigger
board.
It's clear from the partial transfers that you are getting, that you are
getting into the ball park with  the mixture. You might try two parts
acetone to one part denatured alcohol, to see if that works better.
Harvey
2016-10-07 by K5ESS
Just wondering why you are using ORACAL 651.  A brief search didn’t turn up any other postings or web articles using this material for cold transfer.  Paper products are exclusively used as far as I can tell.  The solvent readily penetrates the paper and after it dries, soaking in water makes it easy to remove while leaving the toner on the copper.
Mike N.
Sent: Thursday, October 06, 2016 6:55 PM
2016-10-07 by alan00463@...
MIke N., see this video showing the use of this medium:
Toner transfer video using Oracal 651 vinyl:
https://www.youtube.com/watch?v=FtmJdCBjwXY
I got the drayer and will have another go at TT with this medium. The Oracal 651 comes stuck to a paper backing. The paper backing peels off. The vinyl then has a sticky side which you can attach to piece of paper and feed through the laser printer. I figured out how to do this using EAGLECAD and made a template so I now know exactly where to attach the sticky vinyl to the paper just before printing it. If the vinyl gives me any trouble, I'll try printing the artwork onto the glossy paper backing before I consider another medium.
73,
Alan
Alan,
I watched the video, an I am convinced that the Oracal works well with
heated transfer, where the heat melts the toner and (hopefully) gets it
to stick to the copper.  I get it. By the same token, the process that
works so well with heat will not respond well to the cold process.
In the cold process, we get the toner to melt using a solvent. The
solvent needs to be absorbed into the backing medium to release the
toner.  The process requirement is the same, we need to melt the toner
and get it to stick to the board.  With a paper backing, the toner gets
surrounded by the solvent, and melts. The pressure gets it to stick. The
backing medium needs to be able to absorb the solvent, and hold it in
contact with the toner. The Oracal is non absorbent, and therefore much
less suited to the cold process. The success you've had with it probably
is because solvent gets trapped between the Oracal and the board. With
enough pressure you might get transfer, but it is hard to believe that
you could get uniform distribution of the solvent.
When you heat process the Oracal, you peel the vinyl off the board, and
leave the toner behind. In the cold process, we soak the paper until it
almost disintegrates, and then we gently rub the excess paper off.  The
toner does not really separate from the paper in the same manner as the
Oracal with heat. There have been many discussions about which kinds of
paper are best for the process. There is a theory that the shinier paper
is better than regular printing paper. That seems to be true in my case.
I use the thinnest, glossiest paper that my printer will handle. The
gloss must not come from a clay coating. Others have had great success
with very hard papers like baking parchment. I had no success with that
paper. The common thread here is that the greatest successes are with
using paper as the print medium.
Just my $.02
Harvey
> medium.
> 73,
> Alan
2016-10-14 by alan00463@...
Thank you for sharing your 2 cents, Harvey.
I tried cold toner transfer on glossy coupon flyers from McDonalds,
but they failed to lift from the paper. Looking around for paper that was "glossy but flexible" to print on, I also found and tried a Techni-tool catalog cover, a CVS Pharmacy sticker backing, and an Avery address label sticker backing. All failed. So I'm postponing my cold toner transfer tries until I can get some Office One "Business Gloss" 32lb. 92 brilliance glossy paper Roland F. Harriston reported worked well awhile back.
Meanwhile, a bunch of my circuit's artwork piled up on a pile of ORACALl 651 vinyl stickers. So I got out the iron & did some that way.
My first impression looked good. So I etched it with ferric chloride and tinned the traces with Tinnit solution. It looked great. Until I looked a little closer and notice I'd forgotten to print the pads on this through-hole board. D'oH!!!! But it had another major flaw -- an unwanted trace shorting out 3 pins on an opamp chip.
So I re-ironed the board by following Adam Kohring's instructions to the letter:
Print Your Own Circuit Boards
EXCEPT I ironed it on for 5 minutes, rather than 2.
It worked. The traces are well-defined. However, about 30% of their
interior is lacking toner where it ought be. Does this mean I need to
buy a new toner cartridge to replace the original one I've been using for
11 years ?
Well, on October 3, I removed the old image and ironed another one on, following Adam Kohring, since I had two more artwork prints. This time I used a timer to ensure I only ironed it 2 min.
It failed. Maybe I didn't hold the iron still enough for 20 s.
Maybe do it for 30 s. However, I DID NOT get the voids in the traces
that I did last time. That's good.
My third try WORKED! YAY! The traces are about 95% covered on
their interiors. I just gotta remember:
2 min. in oven -- 30s holding down the iron--2 min. total ironing.
I will go over the tiny holes w/ Sharpies.
I couldn't really do the holes using the 3X magnifying lens. They
were too hard to see until I put them under the 10X loupe.
Oct 14
I just went over the tiny holes in traces using an ultra-fine tipped
Sharpie. My Vision Technologies VT100 19in. CRT magnifier is inval-
uable for this purpose. I saw holes in the toner as big as
0.005185 of a 0.086 in. trace, or 0.0004 in. That's about 0.4 mil.
I filled 'em in with my ultra-fine-tip Sharpie.
WIlll etch it tomorrow,
Alan
2016-10-15 by Roland Harriston
Cold toner transfer:
Since my name has been mentioned, I thought I might make a comment:
1. There are many types of toners, using different types of heat
sensitive polymers.
2. Each toner is going to have a different "solvent".........for lack of
a better word.
     If you don't use the material that is the "solvent" for the
particular toner you are
     working with, to cannot possibly get a good cold transfer.
3. The paper does not really contribute very much to the cold transfer
process,
     but some types of paper may absorb more of the solvent and thus aid in
     transferring the solvent-softened toner.
4. Some toners may dissolve in several liquids. Others may dissolve in
only one.
     Acetone, xylene and naphtha seem to be the  most common, but there
might be
     toners that don't dissolve in any of the above. So, first, you want
to determine if the
     solvent you are using does actually dissolve (soften) the toner you
are using.
5. Applying heat to ANY solvent can be dangerous.
6. I do not own a laser printer.  I use the same copy store all the
time, and it appears that they
     use the same toner in their machines all the time.  So I  always
Roland F. Harriston
> the letter:
> <https://learn.adafruit.com/how-to-print-your-own-circuit-board/transfer-the-toner>
> 11 years ?
> Oct 14
> Alan
> image
> Begin printing your own circuit boards now!
> View on learn.adafruit.com
> Preview by Yahoo
