Homebrew PCBs
What is the proper way to wire a 3 wire synchronous motor
2017-01-04 by Rob
What is the proper way to wire an AC  3 wire synchronous motor?
There is a wire diagram on this picture but it does not help me.
http://www.learnmorsecode.com/laminator/syncmotor.jpg
Do all 3 need to be attached to make it go clock wise?
counter clockwise?
Which wire is neutral?
Which wire is is hot?
RE: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor
2017-01-04 by K5ESS
Check this out
https://www.youtube.com/watch?v=C11NeRSxPD4
Mike N.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Wednesday, January 04, 2017 9:14 AM
Subject: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor
counter clockwise?
Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor
2017-01-04 by Harvey Altstadter
Rob,
I think this is what you are looking for:
Harvey
> counter clockwise?
2017-01-04 by Rob
Thanks Mike and Harvey.
Thats the one.
On 01/04/2017 11:25 AM, Harvey Altstadter hrconsult@...
> Rob,
> Harvey
>> counter clockwise?
2017-01-04 by Rob
I revised the picture to show the connections.
> counter clockwise?
2017-01-04 by Jim Pruitt
Looks like the direction you want it to travel determines where the AC line connects.
Good luck.
Jim
On Wed, Jan 4, 2017 at 9:34 AM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Thats the one.
On 01/04/2017 11:25 AM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Rob,
I think this is what you are looking for: https://www.youtube.com/watch?v=C11NeRSxPD4
Harvey
counter clockwise?
2017-01-04 by keith printy
Since there appears to be a capacitor present the motor in the picture is wired correctly. If there were no capacitor it would not run.
Sent: Wednesday, January 04, 2017 12:34 PM
Subject: Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor
Thats the one.
Rob,
Harvey
counter clockwise?
2017-01-05 by Rob
What is the purpose of the 0.15uF capacitor?
I find the next size smaller shows it also in this picture:
http://www.learnmorsecode.com/laminator/sync5.jpg
On 01/04/2017 04:35 PM, 'keith printy' keethpr@...
> *From:*Homebrew_PCBs@yahoogroups.com
> *Sent:* Wednesday, January 04, 2017 12:34 PM
> *To:* Homebrew_PCBs@yahoogroups.com
> *Subject:* Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire
> synchronous motor
> Thats the one.
> <mailto:hrconsult@...> [Homebrew_PCBs] wrote:
>     Rob,
>     Harvey
>     <mailto:roomberg@...> [Homebrew_PCBs] wrote:
>         Wh at is the proper way to wire an AC  3 wire synchronous motor?
>         counter clockwise?
2017-01-05 by K5ESS
The motor is built with a number of magnetic poles arranged around the stationary part of the motor (the stator)  alternate poles are wound with the two different windings.  By connecting a capacitor in series with one of the windings (which results in a phase shift across that winding) you get a rotating magnetic field within the motor.  The permanent magnet rotor aligns itself with that field and rotates to keep in alignment.  The direction of rotation of the rotating magnetic field depends on which of the two windings the capacitor is connected in series with.
Mike N
Sent: Wednesday, January 04, 2017 6:40 PM
Thats the one.
Rob,
Harvey
counter clockwise?
2017-01-05 by KeepIt SimpleStupid
In general with a synchronous motor, there will be two windings with a common which you can identify with an ohmmeter.  The suggested cap causes a phase shift.  The AC rated capacitor goes between the free ends of the windings.
Power is then applied to the common and to one end of the capacitor.   The end you choose determines the direction the motor rotates.
Without a capacitor, the motor generally won't run or appear "spastic".  I've never experimented with the capacitor size.
    On Thursday, January 5, 2017 12:16 AM, "'K5ESS' k5ess.nothdurft@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
     The motor is built with a number of magnetic poles arranged around the stationary part of the motor (the stator)  alternate poles are wound with the two different windings.  By connecting a capacitor in series with one of the windings (which results in a phase shift across that winding) you get a rotating magnetic field within the motor.  The permanent magnet rotor aligns itself with that field and rotates to keep in alignment.  The direction of rotation of the rotating magnetic field depends on which of the two windings the capacitor is connected in series with.Mike N  From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Subject: Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor    What is the purpose of the 0.15uF capacitor?
On 01/04/2017 04:35 PM, 'keith printy' keethpr@ameritech.net [Homebrew_PCBs] wrote:
  Since there appears to be a capacitor present the motor in the picture is wired correctly. If there were no capacitor it would not run.  From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Subject: Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor   Thanks Mike and Harvey.
Thats the one.On 01/04/2017 11:25 AM, Harvey Altstadter hrconsult@cox.net [Homebrew_PCBs] wrote:
  Rob,I think this is what you are looking for: https://www.youtube.com/watch?v=C11NeRSxPD4HarveyOn 1/4/2017 8:14 AM, Rob roomberg@... [Homebrew_PCBs] wrote:
counter clockwise?
2017-01-06 by Donald H Locker
The capacitor provides a shift in phase of the excitation to one set of the motor's windings relative to the other windings. This provides a rotating magnetic field which the rotor "follows."
Donald.
> From: "Rob roomberg@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
> Sent: Wednesday, January 4, 2017 7:40:13 PM
> > synchronous motor
> > Thats the one.
> >     Rob,
> >     Harvey
> >         counter clockwise?
