Double sided boards, Help needed.
2004-11-01 by ginettaman2001
Any help or tips on etching double sided boards? I want to etch a double sided board, nothing to complicated. I have etched before using laser transfer method with success, just after some tips for lining up. Alan.
2004-11-02 by Phil
By lining up, I assume you mean aligning the two pieces of paper that have the transfer patterns printed on them. I use 24 lb paper for printing the toner on and a light table to align the top and bottom papers. You can use a sunny window or a slide sorter in a pinch but a light table is the easiest. Also, I use double sided tape from 3M that comes in a handy little dispenser. Most office products stores carry them. Using my layout SW, I draw an outline around my layout before printing. This serves to allow me to line up the two pieces of paper. I tape one piece of paper, toner side up, on the light table glass. Then I place the second paper, toner side down on the first paper. With both hands, I slide the top paper around until I get good alignment. Holding the paper in place with the heel of one hand, I lift one side of the top paper and hold it with the fingers of first hand (one hand both holds the paper down to preserve alignment and one edge of the top paper). With the other hand, I quickly lay down some of the double sided tape on the bottom paper about 2-3" from the edge of the artwork. Then I lay the edge of the top sheet back down and smooth it so the two pieces of paper stick together. I recheck the registration to make sure its ok. Then I tape the papers on the opposite edge from the first tape. Next, I cut it out so there are about 3" all around the artwork. This makes a sandwich that I can slide my prep'd blank into. I also use the light table to get the blank aligned. I use forceps to slide the blank in and tweak the alignment At this point you can feed your board through a laminator, fuser assembly or iron it just like you would for a single sided board. Be sure not to touch either the toner side of the papers or the PCB blank with your fingers. Preserving registration can be tricky with laminators. I've been using a carrier when feeding the board/paper assembly through. Childrens construction paper makes a good carrier. Some one here gave me that hint and it really works well. There are other schemes that, no doubt, will work but I haven't tried them. Making a light table is pretty easy and cheap. I think I paid less than $15 total for the material for mine. --- In Homebrew_PCBs@yahoogroups.com, "ginettaman2001" <pcpro-2@b...> wrote:
> > > Any help or tips on etching double sided boards? > I want to etch a double sided board, nothing to complicated. > I have etched before using laser transfer method with success, > just after some tips for lining up. > > Alan.
