Homebrew PCBs
Best achievable double sided boards?
2004-11-06 by Bob Weiss
Using the "Staples Paper/Ironing" method, what are the best
achievable results you have gotten for a double sided board? I mean
what are the thinest lines (in mm or mils) and space between them.
The reason I am asking is because I just designed a double sided
board that is pretty complicated (I use Eagle Pro) and I don't want
to waste my time if it can't be done at home. I have done single
sided boards before with this method and have gotten great results.
The best I can get this particular board to route 100% is if I use
alot of via's. If I go with a 4 layer and send it out ($$$) then its
not that hard to route. Just trying to get some your prior
experiences and see if I should proceed. Thanks for taking the time
to reply.
Also when dealing with vias how do you solder them? I was thinking
of using thin (30 guage), bare wire and solder it on both sides of
the board. Does anyone have any better ideas?
Re: Best achievable double sided boards?
2004-11-06 by Phil
Its not hard at all to get good registration with double sided boards.
 I dont even bother making single sided anymore.  You need to take
care when ironing to ensure that the paper doesn't move.  When I was
using an iron, I would tack in the middle and work outward.
In terms of line width, I can do 10 mil pretty easily though I prefer
12 mil.  You can get 12 mil through 100 mil pitch parts and it stands
up to the vagaries of the etch tank a little better.
Yes, I use wire in the vias and solder both sides.  I'll use what ever
wire I have that's scrap.  Since I got a couple hundred feet of scrap
cat5, I've been using that.  28 ga, I believe.  I thread the wire
through all the vias and solder them in one pass on each side of the
board.  I then use the wire loops for continuity testing and clip them
off as I determine the via is good.  Its a good, cheap and fast technique.
I know that others use eyelets but my one experiment with them was a
mess and I wound up chucking the board.  You need to make your vias
pretty big (much larger than the eagle default).
The biggest issue I have is via placement.  Since I use a wire to
complete the via, one can't be put under parts that are flush with the
PCB.  Also, you want to be careful not to place a via too close to a
pad as the heat of soldering the pad can cause the via wire to drop
out.  I suppose if you use eyelets, some of this can be overcome.  I
generally dont put vias under things as it allows me access to go back
and touch it up if I muffed the soldering.
Have fun!
Phil
> to reply.
RE: [Homebrew_PCBs] Best achievable double sided boards?
2004-11-06 by Leon Heller
>From: "Bob Weiss" <BWeiss@...>
>Reply-To: Homebrew_PCBs@yahoogroups.com
>Subject: [Homebrew_PCBs] Best achievable double sided boards?
>Date: Sat, 06 Nov 2004 01:35:42 -0000
>to reply.
That's the usual method.
Leon
Leon Heller, G1HSM
http://www.geocities.com/leon_heller
I appreciate your response. I did notice that the default size of
vias in Eagle is kind of small and leaves no room for error. I
bumped them up to 15mil pads. Most of my lines are 10 mil and space
between is 8 mil. The single sided boards that I've done came out
99% good, except a minor line being broken but fixable. When you do
a dbl sided board do you use defaults in the routing parameters or
do you change them and favor 1 side to give less traces on the top?
What is the smallest drill bit you use? Do you "tin" the board when
finished etching?
Thanks!
boards.
was
prefer
stands
ever
scrap
them
technique.
a
a
I
back
> Have fun!
> Phil
mean
them.
want
results.
use
its
time
> > to reply.
thinking
of
2004-11-06 by Phil
> finished etching?
> Thanks!
Using the Eagle autorouter guarantees a more complex board.  I route
by hand and favor the bottom for TH and the top for SMD.  I'll put
SMDs on the bottom of mostly TH boards.  Basically, I try to route a
single sided board and then use the other side for a ground plane or
the last few traces that dont fit.  I do hate to drill so "Phil's
Design Rules" minimize hole count.
Smallest drill I use is a function of what I have.  I got a good deal
on a lot of #69 bits so its my smallest (0.032, iirc) but I would go
smaller for the vias if I had the bits.
I used to use tinit but dont bother any more.  It was just one more
step in the process for marginal benefit, IMO.  If you solder right
away and use liquid flux (particularly for SMD ICs) there will be no
problem.
2004-11-07 by mikezcnc
While I had no problems achiving fine traces (15mils) with small
boards 1 sq in using ironing, it was impossible for me to make a
100x160mm PCBs and the best I had was 70 or 90% exactness. I went
thru every possible trick mentioned on this forum to balance the
temperature, pressure and time and notning gave me results as good as
using a different heat transfer method (at that time the fuser method
was not well known). Mike
PS by different heat transfer method I mean using a laminator and
Staples paper (suggested first by Tom Gootee), And yes I did try all
kinds of other injet papers, I still have a pile of them and none of
them worked well on LARGE PCCBs. If TT works well on a large PCB
therefore it will work well on any smaller PCB as well.
