ICC curve does not work
2012-03-01 by RodB
I am new to using QT Rip and making profiles. Following is what I did: (iMac running Lion OS, Epson 1400 printer) 1) Created a txt file from the L values, 2) Dragged the txt file into the QT Rip "Create ICC" icon, 3) Installed the ICC profile in the Library/ColorSync/Profiles folder, 4) Opened Lightroom 3, Print Module, 5) Selected the Printer to "Quad1400-K6", 6) Changed the Layout window to "Quadtone Rip", 7) Set the Mode to "Quadtone Rip 16 bit", 8) In the Curve 1 window, selected the profile I made, 9) Selected "Print" The printer "fires" and the output is a blank sheet of paper. I changed the Mode to "Quadtone Rip 8 bit" and printed a blank sheet of paper. I also tested the printer by selecting another profile that is not for the paper I use and the printer produced a print. What am I doing wrong?? Thanks, Rod
