I had a similar problem maybe ?and Roy sent me this and it worked,
What's going on is that the Preset (actually Last Used Settings)
has both QTR settings and Epson settings. The Epson settings come
from some previous
printing that had borderless 13x19 printing. So it sets this
variable to expand the size by
3% (Epson does this to make sure there's no white line on side). So
in the end the
13in wide is multiplied by 1.03 which is too big. Pretty weird and
contrived but that's whats happening.
I tried to find a way to clean up a particular Preset but OSX seems
pretty determined.
The most foolproof is probably to Trash all the preset files and
reboot the computer
and start from scratch. But the less drastic way that I think will
work is:
When you are trying to make a Preset, first select Printer, second
select Standard as
the Preset, (or on newer OS's its called Default Settings.
select all the options you want and then in the Preset - Save As a new
name.
The main thing here is not to start with an existing Preset which may
have old values in it.
Another thing that I'd recommend is to always use Presets for a
particular printer not
all printers. -- you should see that in the Preset Save window. Be
sure to keep Epson Presets separate from QTR Presets.
On Sep 10, 2012, at 4:34 PM, clayharmon47 wrote:
> I have been using QTR for almost seven years now, and I have
> recently run into an issue when using rolled paper on my 7800. What
> happens is that I set up a custom size print, say 11x22 inches, and
> pick all the rest of my QTR stuff the way I normally do. The print
> preview on the CS5 print dialog box looks fine. But when I actually
> print, the printer won't go past the 8-�" width of a letter size
> sheet.
> I deleted the entire QTR installation using the instructions in
> the .pdf included with the distribution and reinstalled. Still
> having the problem. What is strange is that I can select sheet fed
> sheets larger than letter size, change the feed type on the printer
> from roll fed to sheet fed, and it works fine.
> Any ideas? Has anyone else run into this? Do I need to reset the Mac
> printing system?
