Newbie attempting P Roark B&W printing with Claria colours in Epson 1500 (1430)
2013-01-07 by rossfmj
Hello, this is my second posting. I am new to digital photography and attempting to follow the QTR route to producing black and white. Most of the information I am finding, here and via QTR, Paul Roark etc is way above my current understanding, so I am floundering quite a bit in the dark. I am currently using a Mac running OSX 10.8.2 Mountain Lion Photoshop Elements 11 Epson Stylus Photo 1500w (identical to Epson Artisan 1430) I have installed QTR 2.7.2 I am hoping to use MIS UT14 inks in the near future As a starting point I have tried to follow Paul Roark's approach to B&W using Epson 1400 Claria Inks and his profiles relating to this and am now completely and utterly befuddled. I have installed the printer as Quad 1400 using Roy Harrington's InstallScript 1400 with Paul Roark's Profiles Etc. (Or so I thought) I'd be grateful if anyone could answer any of the following questions; Am I correct assuming QTR is not a stand alone application on my setup but only comes into play when "print" is selected from an application? Would Paul Roarks approach work in my set up? (He suggests importing a TIFF into QTR, which I can't do as QTR is not an application, and I cannot get his curves in printing via QTR, all I can get are Claria-2880-EPGP and Claria-2880-HFBG-BO). Will my set up above be able to use MIS UT14 inks successfully? Can anyone suggest articles or sites which would help someone at the bottom of a steep learning curve get to grips with printing in B&W. Thanks Ross
