No QTR in Print tool
2017-05-06 by stevencrawford535@...
Hi All,
I am having a problem
I am having problems with my print tool.
I printed a Print 51 Step Chart and Cure Overnight. Measured W/ColorMunki &
export from ColorMunki Color Picker; Comma Separated. Opened the Open Comma Separated File Google Sheets https://docs.google.com/spreadsheets
Copy the Numerical LAB Numbers (command c), Open Piezography Error Colrection
Link 51 Steps Sheet, Past the LAB Info, Download as TSV. Move to file with
original .quad file
Drag and Drop both Original .quad and new TXT files, QTR Linearize Quad, Delete
TXT files Rename new .lin-Quad. Then when I Install3880-PiezoDN and opened the
print tool, there is no option from the dropdown menu to select QTR. I did uninstall and reinstall QTR, Print Tool,
and Piezography.dng. Restarted my computer. I am runing Mac Sierra. Also, When
you open the Print tool, when you choose paper size, it only allows you to
choose letter and QTR in not an option here as well.
Thank you in advance
