QTR-Quadtone RIP
Re: [QuadtoneRIP] Epson SC-P400
2018-03-23 by Roy Harrington
I have not worked with a P400 but reports are that it is indeed compatible with R2000.
So you should be able to use QuadR2000 (not Quad2000 -- the "R" is important).
Roy
On Tue, Mar 13, 2018 at 5:50 AM, romcra123@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Hi, everyone -
I am new to QTR. As as matter of fact I have not used it yet.
I have an Epson SC-P400 and I was wondering if QTR will work with it. I do not see it being included as such in the compatible printers list. R2000 is and P400 being nearly the same as R2000 in most everything as far as I can tell, can one select Quad2000 as the Printer Model?
I am making digital negatives and unfortunately the the the best ink opacity obtained on P400 is woefully inadequate and unlike the more expensive SureColors the P600 and P800, the P400 driver from Epson has no dial to increase the ink density. I was hoping QTR can provide this ability.
Any suggestions welcome.
- Roman
