Neutral Prints With QTR and 7890
2018-05-15 by deanwork2003@...
I recently set up a restored 7890 with a new head that I will be converting to Piezography Neutral K7.
Before I did that I wanted to see how good I can make some neutral prints with the Epson color inks out of qtr for teaching purposes. I used to use QTR with older epson printers but it has been a LONG time.
I just set up an Epson P800 for one of my clients and right off the bat we made some lovely totally neutral prints on Platine with the existing generic Neutral curves. It was so good I was a little shocked at how clean and uniform the hue was in all areas of the ramp.
Anyway I was playing with the 7890 last night with Canson Rag Photographique and see that there are no neutral qtr curves with these previous printers ( I assume the same is the case with my 3880 ) and that you need to blend a warm with a cool. The "selenium" curve is so magenta it seems totally unworkable to me.
So what are people using for a clean neutral on Photorag or Rag Photographique and Platine. You have three curves to blend. I have used one warm and one cool together so far. Still seems a little cool to me on Rag Photo and Photorag but it might be good for Platine with PK which I haven't tried yet. Are there any other
formulas I should play with? And/Or does anyone have a custom curve that I could try out for either the 7890 for the 3880 in neutral hue? I don't see many curves for more recent printers in the Files section here.
John
