QTR-Quadtone RIP
Neutral profile for p600
2018-11-16 by carlitosvargas2002@...
Hi.
I've been trying to get a neutral QTR profile for a while now. The profiles I made are either warm, or cold, or worse, warm on one side and cold on the other. I already made many versions of the profiles. Is there any way to get a true neutral profile, other than by trial and error? Linearization is not a problem, I can linearize them properly. I'm using Windows10, an Epson SC -p600, John Cone inks, Canon Photo Pro Luster paper and Hahnemühle Fine Art Barita.
Thank you
Carlos Vargas
Re: [QuadtoneRIP] Neutral profile for p600
2018-11-17 by forums@walkerblackwell.com
Dar Carlos. If using cone inks, the best place to ask this is community.inkjetmall.com <http://community.inkjetmall.com/> Not sure what inkset you are using . . . . but Piezo is monochrome so not really able to change its color exactly unless you are using Pro ink.
Best,
Walker
> On Nov 15, 2018, at 8:23 PM, carlitosvargas2002@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Hi.
> Thank you
> Carlos Vargas
2018-11-17 by carlitosvargas2002@...
I'm not using Piezo.
I use the same inks as the OEM.
Black, grey and light grey. That's why I was looking for information here.
Carlos Vargas
2018-11-17 by Keith Schreiber
Carlos,
If you are using ConeColor inks, which seems to be what you are trying to say, the IJM forum that Walker referred you to may still be a good place to pose your question. There may be people here who have made good profiles with them for K3 QTR B&W printing on a P600, or maybe not.
Keith
Keith Schreiber
jkschreiber.com
> On Nov 17, 2018, at 10:30 AM, carlitosvargas2002@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Carlos Vargas
Re: Neutral profile for p600
2018-11-17 by brian_downunda@...
Carlos
Trying to create a QTR curve with a particular toning for a K3 inkset, including neutral, by changing how much of which colour inks are used is a challenge that only a few people seem to have the skills for, and I'm not one of them. I had a problem with my OEM 3880 in that the QTR neutral curves are not really neutral. They're ever so slightly warm, not objectionably so, but they're not neutral. I "cured" this by linearising the neutral and cool curves and then blending them in QTR roughly 85% neutral and 15% cool. The proportions will depend on the paper.
This is a trial and error process that I simplified a little by using a layered TIFF. You duplicate the image and convert one copy to the warm ICC and one to cool and then back to AdobeRGB and then stack the files in a TIFF and play with the layer transparencies. This assumes that you've created and ICC for the curves as part of linearisation.
That all said, I'm a little surprised that the P600 curves that ship with QTR are not neutral. The P800 curves have a reputation for being so. I wonder whether the P800 curves would work in the P600 give the similarities of the printers.
