QTR-Quadtone RIP
drop curve
drop curve
2009-02-12 by jconison77
Hello,
I'm running OS 10.5.6 & using QTR 2.6.2.
When I drop my ink descriptor file into the 'Drop quad profile' I receive a message that says
'Illegal curve name: must contain only letters, digits underscore, or dash'. In the ink
descriptor file where it says Curve_name= I entered "hahntwo". (no qutoation marks)
Why would I be receiving this message?
Thanks
Joel
Re: [QuadtoneRIP] drop curve
2009-02-13 by Roy Harrington
Hi Joel,
The CURVE_NAME variable is not used any more.
The curve name is now taken from the name of the ink descriptor file,
so this file name is the one that should have no special characters.
Roy
On Thu, Feb 12, 2009 at 12:58 PM, jconison77 <jcon77@...> wrote:
> Hello,
> Thanks
> Joel
2009-02-13 by Joel Conison
Hi Roy,
I eliminated the Curve_Name so it now reads just CURVE_NAME=
Nothing is entered as curve name. I renamed my ink descriptor file
7800_K7_indescriptor_2. When I drop it into 'Drop Quad Profile I
receive the same message  illegeal curve name.
Any help would be appreciated
Thanks
Joel
On Feb 12, 2009, at 7:46 PM, Roy Harrington wrote:
> Hi Joel,
> Roy
> wrote:
> > Hello,
> qutoation marks)
> > Thanks
> > Joel
> > Yahoo! Groups Links
That name works fine here -- same OSX version, same QTR version, same printer.
Check the filename again maybe you have a space at the end.
You want:   7800_K7_indescriptor_2.txt   not  7800_K7_indescriptor_2 .txt
Roy
On Fri, Feb 13, 2009 at 6:33 AM, Joel Conison <jcon77@...> wrote:
> Hi Roy,
> Thanks
> Joel
>> Hi Joel,
>> Roy
>> wrote:
>> > Hello,
>> qutoation marks)
>> > Thanks
>> > Joel
