"Terry" <TerryGls@...> wrote:
> Paul,
> I've read the 3-4 PDFs and related links to using PK ink for the R800 / R1800 (ESCR800-4-PK) and other various combinations.
> If I wanted to keep things simple,...
Once you leave an established inkset and workflow, you're no longer keeping things simple.
> since I think I can work my warm LensWork type brown QTR curves to a more neutral black,
> and only use your PK ink in place of the Epson PK ink,
I don't have a PK. I have used a lot of MIS PK (warm carbon), I've designed neutralized PKNs that MIS has picked up, and I now use HP PK for brochures. That's about it.
I write up experiments and have made inkset designs that MIS has commercialized, but I only actually use and am able to offer continuing support to a few.
> use refillable cartiages,
Yes, they are very handy. I definitely am a fan of user-filling carts and CIS/CFS units.
> and print on Epson Ultra Prm Luster ...
Aside from my brochures, I mostly print on matte papers. Glossy papers have too many side issues for my type of printing. So, I'm currently a big fan of HP PK black only in a 1400, but aside from that, I don't print much glossy.
I might add that with the HP PK in the 1400 and a QTR BO workflow, I have less bronzing than an inkset that uses dilute inks, but it's still there. I don't care about it, frankly. I don't mess with glop. The HP PK BO approach in the 1400 has no pizza wheel marks, in part, perhaps, because the HP PK, by itself, with excess water in dilute inks and no glop, dries faster -- by the time it reaches the pizza wheels it's not longer tacky. The HP PK is also microbanding free in my unit and in its current cyan position, unlike the last MIS PKN I tried BO in the 1400. Again, I use HP PK. With BO the mileage I get from the Z3100 cart is so good I just don't worry about the cost of that cart from Altex.
> What other items would I need to purchase to accomplish? Would cleaning only the PK position be required?
Probably that's all you'd need to clean. Even that may be unnecessary -- but a good idea. I like to clean if the ink types are different.
With some chips from third parties there is a conflict with the Epson OEM chips. So, save the Epson carts. If there is a conflict, it's easy to put the Epson chip on a cart (or the other way around). Chips can be reset and used for a long time.
> What if I wanted to return to using the Epson PK cartiage?
No real difference. Most of this stuff is plug and play -- see what happens. The third party ink companies have tried to make their products compatible.
> As I understand the Dmax would be greater than 2.5 on Epson Luster and even higher on the other two papers?
It all depends of paper and ink. I'm not sure what ink you're looking at.
> I'm getting 2.2+ now measured on my X-Rite 810.
The coated PKs keep a higher dmax than the uncoated. The MIS uncoated will start high, but the glossy comes from a glop that is in the base. As it dries, the dmax is reduced due to lower gloss. Some like this lower gloss, and above 2.2, there is very little real world visual difference.
One thing to reiterate, I used a 3-MK workflow in my 1800 because a single channel microbanded. I'm skeptical that a single PK in an 1800 or 800 will be free from microbanding, but maybe my 1800 is just a bad one.
Good luck with the project.
