QTR-Quadtone RIP
Using QTR Create ICC for Non-QTR printers
2009-12-27 by ScottH
I have a question about using Create-ICC for creating ICC luminance profiles for Non-QTR printers.
I use a printing service to print monochrome images on color paper. I believe they use Lambda printers. The output from neutral RGB images is wonderful however I notice luminance differences especially in the shadows.
I have used the Create-ICC method to correct images when printing from Photoshop to my inkjet but it's not clear how I would use this when sending images to a service.
The service wants my images in AdobeRGB. Would the steps be:
1. Create the ICC profile (which to use QTR-Create-ICC or QTR-Create-ICC-RGB).
2. Convert the RGB image to the ICC profile.
3. Assign to AdobeRGB.
4. Save the image and send to service.
Thank you
Scott
Re: [QuadtoneRIP] Using QTR Create ICC for Non-QTR printers
2009-12-29 by Roy Harrington
That looks like the right procedure.
Use the QTR-Create-ICC-RGB otherwise you won't be
able to Assign AdobeRGB in (3).
Roy
> Thank you
> Scott
2009-12-29 by Paulo Baptista
first post in a very long time;  I may be wrong, but  wouldn't it be
the inverse procedure - Assign the created ICC profile to the RGB
image and then Convert it to AdobeRGB to send to the print service? Or
am I missing something?
Best,
Paulo
> Roy
>> Create-ICC-RGB).
>> Thank you
>> Scott
>> Yahoo! Groups Links
