Install prob R1900 OSX 10.7.1, Mac Pro
2011-10-05 by genenphotos
I'd appreciate some help on this -- can't install the QuadR1900 ppd file on a Mac Pro, OSX 10.7.1. The 1900 printer is installed and runs normally through PS CS5 print dialogs. Per Tutorial directions, I found and ran the InstallR1900.command file (I show file extensions.) The resulting dialog appeared in the Terminal window. Note the last 5-6 lines: $ /Applications/QuadToneRIP/Profiles/R1900-UC/InstallR1900.command ; exit; DEBUG2: Directory "/Library/Printers/EPSON/CIOSupport/EPSONUSBPrintClass.plugin" permissions OK (040755/uid=0/gid=80). DEBUG2: Directory "/System/Library/Printers/Libraries/USBGenericPrintingClass.plugin" permissions OK (040755/uid=0/gid=0). DEBUG: load_classdriver(/System/Library/Printers/Libraries/USBGenericPrintingClass.plugin) (kr:0x00000000) DEBUG: load_classdriver(/Library/Printers/EPSON/CIOSupport/EPSONUSBPrintClass.plugin) (kr:0x00000000) Creating printer named: QuadR1900 lpadmin: Unable to copy PPD file. Installing QuadToneRIP Curves Printer QuadR1900 Couldn't open /etc/cups/ppd/QuadR1900.ppd for reading: No such file or directory logout Thanks for any help. --Gene
