Is this an SDSV?
2014-06-30 by jose_sds8@...
Index last updated: 2026-04-28 23:14 UTC
2014-07-01 by alfpaches@...
Toms absolutely SDSV
About the snare, I´ve seen this concert a lot of times but I´m not sure. I think it´s not from a SDSV.
2014-07-01 by jesper
jose_sds8@... [Simmons_Drums] skrev 2014-07-01 01:08: > Hi mates > > https://www.youtube.com/watch?v=vNpbsPfaZEE > > I'm trying to get that sounds with an SDSV but i don't how to do it. > What effects could have that snare? toms? > > Regards. YMO used a lot of other drum synths as well. Most known are the Ult-Sound DS-4 and I think that is a better candidate for the snare sounds here. -- electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se --- Angaudlinn on iTunes: https://itunes.apple.com/us/artist/angaudlinn/id582356650 Angaudlinn on Amazon: http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss Angaudlinn's playlist på Spotify: http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo Angaudlinn on facebook: https://www.facebook.com/Angaudlinn
2014-07-01 by JenkinsC01@...
JenkinsC01@... [Simmons_Drums] skrev 2014-07-01 14:06: > The equipment list for the 1983 album BGM lists Pollard equipment as > well as Ult-Sound, so it may have been a Syndrum (but they tend to be > better for quirky effects than for snares). I have a Syndrum Quad and used to own a Ut-Sound DS-2, but maybe Thomas can enlighten us. I think he has both (and tonnes more). BTW, Syndrums and good for snares too. It just depends on the snare you're after. :D -- electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se --- Angaudlinn on iTunes: https://itunes.apple.com/us/artist/angaudlinn/id582356650 Angaudlinn on Amazon: http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss Angaudlinn's playlist på Spotify: http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo Angaudlinn on facebook: https://www.facebook.com/Angaudlinn
2014-07-01 by Thomas Heckmann
2014-07-01 by Nick Zampiello
i think there is a drum machine on the side by the fan. table top with a sloped top. not likely an SDS5. i hear linn sounds and other sounds maybe it's an SDX off stage? or sampler? NEW ALLIANCE EAST!!!! -------------------------------------- New Alliance East - Mastering New Alliance East - Facebook X :::: B :::: S On Tuesday, July 1, 2014 8:58 AM, "Thomas Heckmann troperecordings@... [Simmons_Drums]" <Simmons_Drums@yahoogroups.com> wrote: Hi guys, the snare and toms are SDSV in my opinion and I can get the sounds easily with mine and they are classic sounds. Not sure about the bassdrum, but I cannot see the rack or brains of Takahashi. Keep in mind they mixed the sound of the venue with the recordings, so you get unusual reverbs. Also keep in mind that the SDS V sounds different when played with the original riot shield pads then using it with triggers from a drummachine i.e. They used ULT-4s in previous pre Simmons years and you can usually see all the ULT pads with Takahashi easily. Hope that helps :-) Best, Thomas Thomas P. Heckmann Trope Recordings - Trope Mastering - AfuLimited - AFULAB On Jul 1, 2014, at 1:08 AM, jose_sds8@... [Simmons_Drums] wrote: Hi mates https://www.youtube.com/watch?v=vNpbsPfaZEE I'm trying to get that sounds with an SDSV but i don't how to do it. What effects could have that snare? toms? Regards.
2014-07-02 by paistekid@...
2014-07-02 by jesper
If it's "just" the pad that is wacko, I'd open it and check if the piezo element has died. Piezos are cheap and easy to find. They basically generate a voltage that is larger if you hit harder (i e louder). Don't trash anything 'cause it's dead. The electronic parts inside a pad can easily be counted. 1-2-3? If you mean that there are problems at the other end (verifying this with other pads etc) it can be trickier, but everything can be repaired. It's not rocket science. -- electronically yours, jesper paistekid@... [Simmons_Drums] skrev 2014-07-02 03:09: > Just wondering if anyone here has any tips on how to fix the triggering > component for my SDSV pads. It seems the sensitivity of the surface no > longer works. Is it something that can be replaced electronic-wise? I > really don't want to get rid of the pads because of this reason. SDSV > pads are rare these days especially the ones in blue color. Any info is > greatly appreciated! - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se --- Angaudlinn on iTunes: https://itunes.apple.com/us/artist/angaudlinn/id582356650 Angaudlinn on Amazon: http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss Angaudlinn's playlist på Spotify: http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo Angaudlinn on facebook: https://www.facebook.com/Angaudlinn
2014-07-06 by paistekid@...
2014-07-08 by superwolle70@...
2014-07-08 by jesper
superwolle70@... [Simmons_Drums] skrev 2014-07-08 15:03: > Don't remove the playing surface! The transducer is glued under the > bottom side of the plywood, so you need to screw of the bottom shell to > access/replace the piezo What Wolfgang said ^^^^^^^ :) -- electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se --- Angaudlinn on iTunes: https://itunes.apple.com/us/artist/angaudlinn/id582356650 Angaudlinn on Amazon: http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss Angaudlinn's playlist på Spotify: http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo Angaudlinn on facebook: https://www.facebook.com/Angaudlinn
superwolle70@... [Simmons_Drums] skrev 2014-07-08 15:11: > Here are pictures of a complete restoration of "a piece of junk". It's > in German but the pictures will give you an idea what's happening inside > http://www.drummerforum.de/forum/36496-wolle70-minimal-auf-seite-22/thread17.html#post1078756 "Was sich da offenbarte grenzte an biologischen Kampfstoff." :D It certainly looks dangerous in the images! :D "könnte man im Notfall auch noch als Vogelbad oder Salatschüssel nehmen" I think a frosted set with mounted LEDs inside so that it lights up upon hit would've been cool. 80's cheesy?! I don't care! -- electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se --- Angaudlinn on iTunes: https://itunes.apple.com/us/artist/angaudlinn/id582356650 Angaudlinn on Amazon: http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss Angaudlinn's playlist på Spotify: http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo Angaudlinn on facebook: https://www.facebook.com/Angaudlinn
2014-07-08 by Nick Zampiello
what did he use to remove the paint. i want clear pads! NEW ALLIANCE EAST!!!! -------------------------------------- New Alliance East - Mastering New Alliance East - Facebook X :::: B :::: S On Tuesday, July 8, 2014 9:47 AM, "jesper jesper@electronic-obsession.se [Simmons_Drums]" <Simmons_Drums@yahoogroups.com> wrote: superwolle70@... [Simmons_Drums] skrev 2014-07-08 15:11: > Here are pictures of a complete restoration of "a piece of junk". It's > in German but the pictures will give you an idea what's happening inside > http://www.drummerforum.de/forum/36496-wolle70-minimal-auf-seite-22/thread17.html#post1078756 "Was sich da offenbarte grenzte an biologischen Kampfstoff." :D It certainly looks dangerous in the images! :D "könnte man im Notfall auch noch als Vogelbad oder Salatschüssel nehmen" I think a frosted set with mounted LEDs inside so that it lights up upon hit would've been cool. 80's cheesy?! I don't care! -- electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se --- Angaudlinn on iTunes: https://itunes.apple.com/us/artist/angaudlinn/id582356650 Angaudlinn on Amazon: http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss Angaudlinn's playlist på Spotify: http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo Angaudlinn on facebook: https://www.facebook.com/Angaudlinn
2014-07-22 by superwolle70@...
