P3 tools for sequentixP3
2011-05-04 by Simon Carbonnel
Index last updated: 2026-04-28 23:15 UTC
Hello! I send you this message because I have a problem with P3TOOLS (version 2). I can not copy normally bank on a site. It still lacks some common patterns.Is this normal? Is there a manip installation do? Thanks a lot for this excellent machine. You can hear what i do on www.myspace.com/ACNE72 [Non-text portions of this message have been removed]
2011-05-04 by Colin Fraser
Hi Simon, > I send you this message because I have a problem with P3TOOLS > (version 2). I can not copy normally bank on a site. It still > lacks some common patterns.Is this normal? Is there a manip > installation do? I appreciate it can be difficult to explain a technical problem in a non-native language, but I can't follow what the problem is here. Is this a problem copying patterns around inside P3 Tools, or with the data transfer to/from P3 ? Can you give a bit more detail of which P3 OS version you are using, how you have things connected, and what process you are following to transfer data ? Best regards, Colin Fraser Sequentix Music Systems Ltd http://www.sequentix.com
Hi Colin, thanks for your reply, I am preparing a set with several patterns that I could follow up. The problem is that my patterns are in the wrong order. I therefore wish to use P3tools to rearrange my patterns. I have no problems during the transfer, the problem is copying patterns around inside P3 Tools. When I made a "bank copy" then "paste bank" some patterns are erased or distorted ... I use the V4.5beta for my P3, i installed it with P3tools(version1). Sorry for my difficulties in english! Musicalement Simon To: analogue-sequencer@yahoogroups.com
From: colin@sequentix.com Date: Wed, 4 May 2011 11:49:44 +0100 Subject: RE: [analogue-sequencer] P3 tools for sequentixP3 Hi Simon, > I send you this message because I have a problem with P3TOOLS > (version 2). I can not copy normally bank on a site. It still > lacks some common patterns.Is this normal? Is there a manip > installation do? I appreciate it can be difficult to explain a technical problem in a non-native language, but I can't follow what the problem is here. Is this a problem copying patterns around inside P3 Tools, or with the data transfer to/from P3 ? Can you give a bit more detail of which P3 OS version you are using, how you have things connected, and what process you are following to transfer data ? Best regards, Colin Fraser Sequentix Music Systems Ltd http://www.sequentix.com [Non-text portions of this message have been removed]
Hi Simon, > I am preparing a set with > several patterns that I could follow up. The problem is that > my patterns are in the wrong order. I therefore wish to use > P3tools to rearrange my patterns. I have no problems during > the transfer, the problem is copying patterns around inside > P3 Tools. When I made a "bank copy" then "paste bank" some > patterns are erased or distorted ... I use the V4.5beta for > my P3, i installed it with P3tools(version1). I think this is likely a compatibility problem between P3Tools 2 and v4.5 data. v4.5 uses the same basic structure of data as v4, but the behaviour is slightly changed. Instead of having each pattern belong to a specific part and track (the Pn:Tn numbers shown in P3 Tools), each pattern has a number from 1 to 64. Patterns can be assigned in any part/track location, but they can also exist 'unused' in v4.5 They can't do that in v4. That might be the cause of the missing patterns. I'm not sure if this can be fixed. I didn't write P3 Tools, though I think I have a copy of the source somewhere. I'll need to check with the author if this is likely to be the problem, and whether it would be 5 minutes or 5 weeks to fix it. Best regards, Colin Fraser Sequentix Music Systems Ltd http://www.sequentix.com
Thanks a lot for your reply and your research!! Simon To: analogue-sequencer@yahoogroups.com
From: colin@sequentix.com Date: Wed, 4 May 2011 17:11:00 +0100 Subject: RE: [analogue-sequencer] P3 tools for sequentixP3 Hi Simon, > I am preparing a set with > several patterns that I could follow up. The problem is that > my patterns are in the wrong order. I therefore wish to use > P3tools to rearrange my patterns. I have no problems during > the transfer, the problem is copying patterns around inside > P3 Tools. When I made a "bank copy" then "paste bank" some > patterns are erased or distorted ... I use the V4.5beta for > my P3, i installed it with P3tools(version1). I think this is likely a compatibility problem between P3Tools 2 and v4.5 data. v4.5 uses the same basic structure of data as v4, but the behaviour is slightly changed. Instead of having each pattern belong to a specific part and track (the Pn:Tn numbers shown in P3 Tools), each pattern has a number from 1 to 64. Patterns can be assigned in any part/track location, but they can also exist 'unused' in v4.5 They can't do that in v4. That might be the cause of the missing patterns. I'm not sure if this can be fixed. I didn't write P3 Tools, though I think I have a copy of the source somewhere. I'll need to check with the author if this is likely to be the problem, and whether it would be 5 minutes or 5 weeks to fix it. Best regards, Colin Fraser Sequentix Music Systems Ltd http://www.sequentix.com [Non-text portions of this message have been removed]
2011-05-10 by em_dkj
--- In analogue-sequencer@yahoogroups.com, "Colin Fraser" <colin@...> wrote: > I'll need to check with the author if this is likely to be the problem, and whether it would be 5 minutes or 5 weeks to fix it. Yep; That change will give P3Tools2 quite a headache. I'm afraid its definitely a lot more than 5 mins to fix that one. Dave
2013-06-14 by simon.carbo
Have Do you have any news about the update of p3tools?? Thanks Simon --- In analogue-sequencer@yahoogroups.com, Simon Carbonnel <scarbonnel@...> wrote:
> > > Hello! > > > I send you this message because I have a problem with P3TOOLS (version 2). I can not copy normally bank on a site. It still lacks some common patterns.Is this normal? Is there a manip installation do? > > > Thanks a lot for this excellent machine. You can hear what i do on www.myspace.com/ACNE72 > > [Non-text portions of this message have been removed] >
