Mackie Control, switching between faders 1-8, 9-16 etc in CubaseSX/Nuendo 3
2009-02-07 by thephaedrus
When using BCF in MC mode or HUI mode,  The Cubase/Nuendo Mixers don't
respond when you toggle between banks of faders.
Yes, I realize that you can hit a select button in MC control to
"jump" the mixer ahead and in HUI mode you can just touch a fader for
it to jump over.   But this is a pain.... I expect more.
Am I the only one pissed off that Cubase/Nuendo has this limitation?
In Protools, the Mixer responds to every bank select.
Has this changed in recent versions of Cubase/Nuendo?
Has anybody gotten the bank select to immediately toggle the mixer over?
Phaedrus
Re: Mackie Control, switching between faders 1-8, 9-16 etc in CubaseSX/Nuendo 3
2009-02-07 by ivaasura
What do you mean exactly? Do you want the BCF to change the fader
banks, if you click with the mouse pointer on a single channel fader
on the screen?
2009-02-08 by thephaedrus
> on the screen?
Mainly I want to have bank selections on the BCF to be reflected in
Cubase mixer, but having Cubase Mixer send bank changes to BCF would
be nice too.
2009-02-09 by goyya76
> > on the screen?
> be nice too.
you could try to assign the SAME CC you use to select a bank (ex: to
switch from track 1-8 to track 9-16) to the selection of the first and
last track of each bank - to clarify:
1)if you switch from bank 1-8 to 9-16 and you select track 16, the
mixer window scrolls right until track 16 is showed
2)if you switch back from 9-16 to 1-8 and select track 1, the mixer
view scrolls left until track 1 is showed
so you could assign the CC you use for bank increment also to "select
track16" (same for bank decrement/select track 1); to do so, just
create another generic remote (that allows to use the same CC for
multiple action - in a single generic remote, only one assignement is
valid as far as i've seen)
i did something like that, it was more complicated (and now i don't
remember....)...anyway that's the idea!
good luck,
Goyya
