> Hello sorry my question but what's the advantage with this trick?
> Can't you get into similar results programming banks in GR ? I'm using a lot of , so the bcr is limiteless in what it can control even with limited cc protocol
> I would like to understand your point , what you can do with this idea that you couldn't with GR concept of banks . I don't understand well the midi channel concept , I see that the midi channel is fixed on GR definitions ( on the top , as well as wich cc is assigned to wich buttim , etc ) . I never cared about it because I never needed to use even a different midi channel on any knob anytime , its always on the channel 01 . In which situation you will use it ?
> I'm using lots of GR I think there's lack of xml files posted here !!!
> DG
> Sent from my BlackBerry� smartphone
> From: yeahtuna <yeahtuna@...>
> Date: Sun, 29 Nov 2009 08:32:35
> To: <bc2000@yahoogroups.com>
> Subject: [bc2000] BCR2000 Make a shift button
> Is it possible to make the Encoder Group buttons function like shift buttons.
> Right now I have this functionality in Cubase by using a combination of the transformer plugin and cubase's generic remote, but I was wondering if I could do this right from the BCR itself.
> The way I've gotten it to work inside cubase is to have a transformer plugin that changes the channel of incoming data from my BCR. So if I have one button that transmits on Chan 16 CC 1, when I hold down my shift button (which activates the transformer plugin) the data is changed to Chan 15 CC 1. I was hoping there was a way to do this entirely in the BCR. I have a BCF2000 running in Mackie Mode (which has shift buttons) so I suspect this is possible.
