Particular driving Waldorf Blofeld by BCR2000
2010-05-18 by virteo
Hello everybody I am a new BCR2000 user and I need some help. I’ll try to explain : I tweak my Waldorf Blofeld with BCR2000. Blofeld is a particular hardware, because it uses a 2 families of MIDI messages to change his sound parameters – MIDI CC and MIDI SysEx. I prepared my own presets for BCR2000 with BCManager of Mountain Utilities (very pleasant soft – thanx to its author). No problems, everything works but… I would like to customize some SysEx messages, (but I don’t know how – I’m not really strong in SysEx programming, far from it) for example: Blofeld proposes a choice of Modulation Sources like that: 0 off 1 LFO 1 2 LFO1*MW 3 LFO 2 4 LFO2*Aftertouch 5 LFO 3 and so on… I captured Blofeld SysEx message that corresponds to this order with BCManager and it looks like that: a b c d e f g h i j F0 3E 13 00 20 00 00 0A 00 F7 F0 3E 13 00 20 00 00 0A 01 F7 F0 3E 13 00 20 00 00 0A 02 F7 F0 3E 13 00 20 00 00 0A 03 F7 F0 3E 13 00 20 00 00 0A 04 F7 F0 3E 13 00 20 00 00 0A 05 F7 and so on… where (according to Blofeld manual): a,b,c,d – a fix values of Blofeld ID e – Sound Parameter change f – Sound Mode Edit Buffer (another value gives a Multi Mode Instrument 1…16 Sound Edit Buffer g – Parameter index high byte h - Parameter index low byte i – New Parameter value j – End of Exclusive I put this line to Custom Output page of BCManager : $F0 $3E $13 $00 $20 $00 $00 $0A val $F7 I put the Min and Max values. Everything works well – I turn the encoder: the LED lights on, BCR sends a message, Blofeld receives the message, but… My master keyboard has no Aftertouch (and some others features) and I would like that BCR passes from LFO1*MW to LFO2 and then “jumps” from LFO2 to LFO3 directly without any access to LFO2*Aftertouch parameter. Could I program that? Thank you for your help Leonid
