no Midi connection?
no Midi connection?
2010-06-09 by VL
I recently bought the BCF2000 and so far I must say it is a big disappointment...the documentation is so bad...well you've heard that before and I should have done some better research before buying...
anyhow...
I am using it with Logic express on a Mac and it can't do much apart from volume and pan ( I was able to enable the logic preset)
But I can't use it as a Midi interface. The manual says press Store and Edit at the same time to access the midi modes, but nothing happens if I do that...what is going on, does anybody know what to do? I just wanted to connect a synth to the midi port and use logic to trigger it.
Also I don't understand the preset, if I press edit I can use the pan and volume fader, but what happens when I press store/learn/exit...are these different modes...sorry if that is a dumb question, but this thing is just a big mystery to me...
thanks
D.
Re: no Midi connection?
2010-06-17 by Phil
I've not tried with Logic Express, but that should offer more than Garageband, which I can use in a limited way with the BCF2000.
First off, you must put the BCF into the right mode - one of the USB modes (see p9 in the manual).   I find USB mode 2 and 3 work OK with the Mac.   To set the mode you press STORE while EDIT is depressed, should get EG on the display.   Then use the top LH rotary to spin thru the modes, which display as U1, U2 etc.   Stop at U2 or U3 then press EDIT to leave the edit/global mode.
In this mode I get MIDI from the keyboard thru the USB into the Mac, and MIDI playout from the Mac to the synth.   (I'm hooked up to a Yamaha keyboard/synth which is all I need).
Because Garageband is not designed for this, you have to download a Midi driver which appears as a virtual output on the GarageBand instrument info - it's a real kludge.   You should get much more integration with Logic though.
Hope this gets you started.
> anyhow...
> thanks
> D.
