sending two drifferent note values with footswitch
2010-06-14 by OlliK
I'd like the footswitch on my BCR send note D5 (vel=127) when pressed and note F5 (vel=127) when released. I'd like this for using MCU mode to switch between track automation Read/Write for emulation touch sensitive knobs.
Is this possible ?
Re: sending two drifferent note values with footswitch
2010-06-15 by Royce
Hi
> Is this possible ?
Sure
Foot switch is 61 or 62
This is what the code should look like.
$button 61
  .showvalue on
  .mode updown
  .minmax $56 $59    ; D5 and F5 (check the octave??)
  .tx $90 val 127    ; val is $56 when pressed and $59 when released
Hope this helps
Royce
2010-06-15 by OlliK
thanks for reply.
Err, noob question alert:
How do I send this text to the BCR, so that my existing preset gets updated ?
(I only transferred pre-made sysex files containing complete presets with BC manager or MidiOx so far).
--- In bc2000@yahoogroups.com, "Royce" <rpcfender@...> wrote:
> Hi
> > Is this possible ?
> Sure
> $button 61
>   .showvalue on
>   .mode updown
> Hope this helps
> Royce
2010-06-15 by OlliK
edit:
Nevermind figured it out.
I have succesfully sent the text with BCL editor.
Everything is working like a charm now.
Thanks a lot for your help.
btw,
this is the first contact I made with BCL, which I wasn't aware of that this exists. Interesting stuff.
--- In bc2000@yahoogroups.com, "OlliK" <NoUse@...> wrote:
> Hi,
> thanks for reply.
> --- In bc2000@yahoogroups.com, "Royce" <rpcfender@> wrote:
> > Hi
> > > Is this possible ?
> > Sure
> > $button 61
> >   .showvalue on
> >   .mode updown
> > Hope this helps
> > Royce
