--- In bc2000@yahoogroups.com, "Royce" <rpcfender@...> wrote:
> Hi
> > I have 2 BCF2000's that up until now I have used separately, trouble free, to control some lighting software. Last week I had the idea of using them together to expand their usefulness, and followed the instructions provided in the user manual.
> How have you connected them??
> > Unfortunately, as soon as I switch out of USB mode 1 my software no longer recognizes the BCF and gives me an error.
> What is the Software??
> > It is as if the BCF has stopped communicating with my computer, and I can't figure out why. Any help would be much appreciated!!
> Does your software know about BCF's or just about midi control?
> Does the software expect to see the BCF as a Midiport??
> What are you actually trying to do??
> Are you trying to make a 16 channel lighting mixer?
> You need to be very specific when asking these types of questions.
> All the best
> Royce
I am using the BCF to control Martin Lightjockey via a program called Faders For Lightjockey. The software will work with any MIDI device that is hooked to my computer, and I can chose my device from a list of installed hardware from inside the program. Using the software I am able to use the faders & rotary encoders to control assigned channels inside Lightjockey; the more faders I have, the more control. To daisy chain them I have switched the first BCF to U4 and the second BCF to S3. When I do this, I get an error from Faders, and it tells me there are no devices installed. I have used other MIDI devices with no such problems, so I am a little confused; am I missing something in the BCF settings??
