Pitchbend 14bit Faders
2011-01-05 by Emre Tanner
Hello dear members,
I am new to this group and would like to say hello to everybody!
This place has helped me a lot already and I´m feeling more and more happy
with my two BCF2000, THANK YOU!
I have one question though:
I´m using my units to control Cubase5, but NOT in Mackie Mode but rather in
B Control mode using  presets (made with GREAT BC Manager) with Mackie
Protocol MIDI mapping. In cubase itself I connect my BCFs as Mackie Controls
which is working fine but I would like to go a step further:
The faders send pitchbend data but in BC Manager I can set the range only
from 1-127. So I put out a text file of the preset and changed the faders
parameters:
I deleted the "easypar" part and put in
.minmax 0 16383
.tx $E0 val0.6 val7.13 (for first fader)
Well, this way cubase indeed responds to fader movements with much better
resolution, BUT the BCF2000´s faders doesn´t catch up with movements within
cubase, so it´s a oneway communication.
Any help to overcome this problem is much appreciated!
Thanks in advance,
Emre
Re: Pitchbend 14bit Faders
2011-01-07 by Mark
> from 1-127.
BC Manager merely follows the capabilities of the BCF in this respect.
> parameters:
> .minmax 0 16383
Another side-note: I'm not sure why you would resort to manually editing text files if you're already using BC Manager: in BC Manager you can make these settings via the fader dialog box's "Custom output" tab.
As far as I know, this problem cannot be overcome: a "custom output" definition (".tx") never responds to incoming MIDI data; only "standard output" definitions (".easypar") do.
It IS possible to use BOTH a standard and a custom definition for the same fader/encoder/button, but I can't see how this would help in this case, in particular since the respective ranges (0-127 and 0-16383) don't match.
Mark.
Re: [bc2000] Re: Pitchbend 14bit Faders
2011-01-08 by Emre Tanner
Thank you Mark for helping me out.
OK, so I´ll leave the faders send 7bit Pitchbend data and smooth out level jumps within cubase, no problem...
Emre
Am 07.01.11 15:34 schrieb "Mark" unter :
> from 1-127.
> parameters:
> .minmax 0 16383
Mark.
