BCR2000 Mackie emulation for Cakewalk Sonar users provided in Files->presets
2011-01-06 by softcore33
Hello to all the members of this community. I found the community while searching for a "Mackie emulation" to use with my BCR2000 and Ableton Live. I found what I wa slooking for in merely seconds and thank you very much for this resourcefull place. In an attempt to offer something back I have been a long time user of Cakewalk's Sonar. A member of its forums and user of Sonar had created long ago a plug in application for Sonar which provides functionality identical to a Mackie emulation for usage with the BCR2000 and Sonar. I did not see this listed in the files so I thought it would be a nice idea to share it with you. After all, the creator of the utility has long ago disappeared from Cakewalk forums and finding the files is very difficult currently. So, FWIW, in the "presets" folder of the community, you will find a "BCR2000 Mackie Emulation for Cakewalk Sonar users.zip" file. Contents of the file include: - a read me text file with some personal notes, warnings I created - a .bc2 and a SysEx file to be used with the "AJ" plug in - the "AJ control console" plug in which must be moved to your hard disk and be installed in order for this whole thing to work inside Sonar Thanks again for this community - I hope my upload will be helpfull to someone in the long run! Greetings!
