BCF problems
BCF problems
2007-02-25 by Geoff Wood
XP SP2, Nforce 2 chipset.  USB2 connection.
Have updated BCF firmware to V1.10 successfully (I think ! - Well it boots
up and says 1.10, and boots into MC-C OK...).  Have BCF V1.1.1.1 driver
installed.
Setting it as the MIDI device, and generic Mackie Control in Vegas seems OK
( Vegas can see the BCF MIDI device), but sliders do not respond.
What makes me think something is wrong in the device driver side of things
is that if I start BCFView after turning on BCF in MC-C mode, I can select
the BCF in the BCView window, but only get the blue rectangle displayed -
never anything more.  With nothing else running.  And when I hit 'Exit'  I
invariably BSOD with something like error in usboci.sys .
Any ideas ?
And isn't the BCF user manual the worst manual in the world ?!!!!
Geoff Wood
 " No trees were damaged in the sending of this message. However a great
number of electrons were highly inconvenienced..."
Re: BCF problems
2007-02-25 by coolguy2g
i ran into this problem a couple days ago when i re-arranged my apt
after panicing for a while i just uninstalled the drivers and
re-installed them
after that everything worked perfectly
hope this helps
boots
> installed.
seems OK
things
select
displayed -
'Exit'  I
> Any ideas ?
> Geoff Wood
RE: [bc2000] BCF problems
2007-03-01 by Geoff Wood
Is it normal that after switching on in MC-C mode, that it should thereafter
always power up in that mode WITHOUT the keypress ?
Also anybody had IRQL_LESS_OR_NOT_EQUAL BSODs in usbohci.sys ? And found a
cause/solution ?
geoff
Re: BCF problems
2007-03-08 by fvdveen
thereafter always power up in that mode WITHOUT the keypress ?
Yes, this is perfectly normal. By using the keypress+switchon, the
corresponding setting for the BCF is chosen and stored.
This is not a bug, but a feature! I personally always use the BCF for
Mackie Control, so I do not have to remember this anymore when
switching on all my MIDI gear with a single masterswitch.
