2011-05-08 by Mark v.d. Berg
--- In bc2000@yahoogroups.com, "alan.gleeson" <gleesonalan@...> wrote:
> I have a BCR2000 for about 6 months. When I "spin" the push
> encoders in an attempt to change values very fast they don't respond as
> expected, sometimes only moving by a few values and in a very erratic
> fashion. Is this because they are optical controls or does this sound
> like a fault. All the push encoders perform in this way. I have tried
> different settings for the encoders but get the same results including
> altering the acceleration settings through sysex. If I move the encoder
> at a slower speed it operates as expected but was hoping to operate at
> speed with these controls.
You're talking about your BCR's "PUSH encoders". So does the problem occur only with the 8 knobs in the top row or with ALL encoders?
In any case I can't imagine that all 8 (or 32) encoders are physically defective. There might be something wrong with the "general" electronics of your BCR, but that doesn't seem very likely either.
Are you sure you're using the correct SysEx messages?
Have you looked at "BC MIDI Implementation.pdf" (available from my website http://home.kpn.nl/f2hmjvandenberg281/ ), section 17.3 ?
If you're using BC Manager, it should be very easy to experiment with different resolutions.
I'm not sure how fast your "very fast" is, but I suppose that at extreme speeds the encoders might indeed start to behave erratically - I've never tried.
But if you set the ".resolution" parameter(s) reasonably high, it shouldn't be necessary to turn the knobs extremely fast.
Hope this helps,
Mark.
