BCR Manager under WINE
2011-06-07 by sghookings@tiscali.co.uk
Mark and Royce (and the nearly world famous German site) I want to "dank u wel" for your efforts here.
The summary is I went down the "hard" route of using your sofware under Linux (WINE) and this lead to a "self help" method for understanding how I can use your GUI to store presets. Until now, I was missing the plot :-(
Thanks ... my issue now ... I recently discovered the upper 1-4 bankable 24 buttons/8 knobs are PER preset :-).
Why is this a problem? I now have an interesting mathematical problem of optimally packing my low range NRPNs/2xbuttons/2xknobs for -ve value NRPNs. That is I have way too many controls now, so which important controls to duplicate, and how?
But what a fabulous problem to have :-))
Background
I have a Miniak, which is a great synth but somewhat lacking interface.
It is okay, in terms of shortcut keys, but I coveted real hardware.
Step 1 - dealing with low range NRPN values
You kindly helped me with the 7 bit NRPN ".tx" to send LSB.
This has its routes in Psionic's initial research in original post.
I could never get the hang of the GUI, inspite of reading the excellent manuals. And I was going to ask about how to send commands in the BCL Editor to make current assignments apply to preset N.
I figured (incorrectly I see now) that the Miniak, being so stupidly non-standard, rendered your GUI useless to me.
But on a different forum some Mac fanboy, who distrusts BCRs, was asking similar questions (how to control a Miniak from external surface).
I explained the only surface I have found that is up to the job is the BCR with your excellent software. Even then, one has to compromise to use 2 knobs for control a -ve range (and it isnt quite a nice as one would like). But I havent found another surface that will let one send "MSB" 7bit value NRPNs as an "LSB" 7bit. Not evern ironically, any of Alesis products (save the Ion) -- assuming I have understood their manuals correctly.
And as for a signed 14 bit ... the midi standard is unsigned 14 bit!!!
Step 2 - flexible control surface
I have researched many control surfaces. Always I missed one or two salient points, but luckily some internet searches and development of Minaktools allowed me to understand the non-standard way Alesis (and hence AKAI) coded the Miniak.
Without your collective software the BCR is of limited value for Miniak programming.
So these Mac fanboys, who for whatever reason suggest they have the perfect environment / OS, are unable to use your software "as is".
I'd read in your manual that some folks have used WINE.
Last night I also did this under Wine 1.0.1 Ubuntu 10.X
I couldnt believe how trivial it was. Simply
  • run wine,
  • find the executable,
  • and it "installs" it under it's virtual program files.
  • Put BCR into USB mode (I chose 3),
  • start BC Manager
  • select the BCR as midi input/output.
  • program up your assignments
  • store this in the presets
  • optionally dump out the complete sysex for backup purposes
"hey presto" there is the BCR.
Now, I know some die-hard Mac fan-boy will say "but I dont want to run that silly unix like OS". Too bad, they are after all BSD with a GUI. But looks like you can run wine "native" on a MAC . I havent tested this because I dont have a Mac.
Else there is this parallels thing on Mac, so they could download an Ubuntu and run that OS to run Wine to run the BCManager to allow the control of the BCR to get the environment to program the Miniak!!!
Step 3 - "But how do you do these .tx from the GUI"
Mark you are a very patient person. I see the scientist in you, xref each answer with a reference to the chapter of your manual. I confess to still not quite understand the concept of standard def (easypar) v custom (tx).
Anyhow, I had watched the flash videos too but I still didnt get how to custom program the GUI.
So I used the BCL editor to send some custom commands to buttons/encoders/knobs.
I spread these over a couple of presets (but did it the manual way; your GUI is a far nicer way to achieve this ... I mean it is after all why you created the software!).
Once I had gotten BCR running under linux, I realized there is a red "receive" midi icon under the B-Control 2 (BCR2000): Presets spreadsheet.
And selecting a given preset, receiving the midi, will open a new spreadsheet with the specific fields completed.
More than that, the layout screen is then also suitably completed.
And I can see "custom" in some of the group buttons (the very .tx I sent via the BCL).
And I can see straight NPRN address in other buttons.
Double clicking on a custom yields
Line Name Output
1 $B0 $63 $00
2 $B0 $62 $0B
3 $B0 $06 $00
4 $B0 $26 val
Oh and value 1 is 0, value 2 is 2, sent to LSB (correct for waveform osc1).
Mode is down
Standard output is None
General: show value is ticked (and it does show value)
Info has a name ... which is blank (but soon will say Osc1Waveform) :-))
And I can put comments in here too!!
If I click in Encoders 1 NRPN 12 (waveshape for miniak osc 1)
Info is blank (this will be rectified)
General is show value, LEDs off (might change this) Speed levels is 1.
Standard output is Non-Registered Parameter Number
Channel 1, NRPN 12 ($00 $0C)
Value 1 : 16284 (-100)
Value 2: 16383 (-1)
Mode: Absolute (14 bits)
Custom output: None.
At last I see what you were driving at in your earlier reply; sorry I was being so dense.
Conclusions
I have "seen the GUI".
I now have enough inductive parameters to generalize, without hassling you.
I hope others who were not sure about using BC Manager under linux will realize it is trivial. And hopefully a Mac fanboy (I am using the British trick that you rib your friends harder than your enemies :-)) will be able to use/validate WINE works for them.
This mean other forums, that suggest the BCR isnt up to the job, doesnt work on their OS etc etc, should be able to google that indeed it can.
Once again, thanks a lot.
Tot ziens
Steve H
Re: BCR Manager under WINE
2011-06-07 by WyleL
You can also run WINE on Mac OS X. (http://winebottler.kronenberg.org/)
> u wel" for your efforts here.The summary is I went down the "hard" route
> 24 buttons/8 knobs are PER preset :-).Why is this a problem? I now have
> Background
> interface.It is okay, in terms of shortcut keys, but I coveted real
> hardware.
> You kindly helped me with the 7 bit NRPN ".tx" to send LSB.This has its
> <http://launch.groups.yahoo.com/group/bc2000/message/2578>   post.
> manuals correctly.And as for a signed 14 bit ... the midi standard is
> unsigned 14 bit!!!
> programming.So these Mac fanboys, who for whatever reason suggest they
> is".I'd read in your manual that some folks have used WINE.Last night I
>     * run wine,
>     * find the executable,
>     * and it "installs" it under it's virtual program files.
>     * Put BCR into USB mode (I chose 3),
>     * start BC Manager
>     * select the BCR as midi input/output.
>     * program up your assignments
>     * store this in the presets
>     * optionally dump out the complete sysex for backup purposes
> <http://wiki.winehq.org/MacOSX>  . I havent tested this because I dont
> have a Mac.
> custom (tx).Anyhow, I had watched the flash videos too but I still didnt
> buttons/encoders/knobs.I spread these over a couple of presets  (but did
> spreadsheet.And selecting a given preset, receiving the midi, will open
> via the BCL).And I can see straight NPRN address in other buttons.
> Line Name Output1         $B0 $63 $002         $B0 $62 $0B3         $B0
> $06 $004         $B0 $26 val
> osc1).Mode is downStandard output is NoneGeneral: show value is ticked
> (and it does show value)Info has a name ... which is blank (but soon
> will say Osc1Waveform) :-))And I  can put comments in here too!!
> Info is blank (this will be rectified)General is show value, LEDs off
> (might change this) Speed levels is 1.Standard output is Non-Registered
> Parameter NumberChannel 1, NRPN 12 ($00 $0C)Value 1 : 16284 (-100)Value
> 2: 16383 (-1)Mode: Absolute (14 bits)
> was being so dense.
> Conclusions
> you.
> Tot ziens
> Steve H
