Windows 7-BC Manager
2011-11-19 by karel skakal
Hello, I installed windows 7, 64 bit and plugged in my BCR2k, everything is OK, BCR shows up in other software.
I downloaded the latest BC manager, started it up and NO BCR detected, it just freezes...
Is there something I have to do? I was on XP before. Is the editor compatible? Do I need some special drivers?
TIA
Re: Windows 7-BC Manager
2011-11-19 by norris_terrify
Hi TIA.
Normally it should work.
I have Windows 7 64 Bit with two BCR's, everything is fine. No problems with them and the BCR-Manager software.
Best regards from Dresden, Germany.
Norris Terrify
Do you have the Vista64 drivers for the BCR?
> TIA
Do you have the BCR-Vista64 drivers?
--- In bc2000@yahoogroups.com, "norris_terrify" <asyncron@...> wrote:
> Hi TIA.
> Norris Terrify
> > TIA
Re: [bc2000] Re: Windows 7-BC Manager
Thanx for reply,
I think normally it should work...but I am new to W-7, so i have no clue...
I get this error:
Error: Cannot open MIDI output device BCR2000
There is not enough memory available for this task.  Quit one or more applications to increase available memory,
 and then try again
and then try again
I have 4GB of memory
cheers
To: bc2000@yahoogroups.com
Sent: Saturday, 19 November 2011, 19:49
Subject: [bc2000] Re: Windows 7-BC Manager
> Hi TIA.
> Norris Terrify
> > TIA
2011-11-20 by karel skakal
THANXS for help, got it working, just needed the 64bit drivers.
Have good weekend
> Hi TIA.
> Norris Terrify
> > TIA
original presets
2011-11-20 by Adam Stalker
i have bought bcr2000 from someone and the presets are all messed up.
how i can revert it to original state or presets?
can't upload the sysex stuff thru bcedit
Re: original presets
2011-11-23 by Mark v.d. Berg
You can use any program capable of uploading sysex files.
Many DAW programs (Sonar etc.) offer this facility.
But if you're only looking for a program that can simply upload the original presets, on Windows you can try MIDI-OX, or my own BC Manager or MIDI Tools (available from http://home.kpn.nl/f2hmjvandenberg281/).
In MIDI Tools: go to View -> System Exclusive messages, then use File -> Insert, select all messages, and "Play" them to your BCR.
BC Manager is more sophisticated, in that it also offers a bidirectional, handshaking uploading method, and that you can edit presets.
Hope this helps,
Mark.
