2012-09-21 by Mark v.d. Berg
--- In bc2000@yahoogroups.com, "mastkopatol" <mastkopatol@...> wrote:
> is there any way of editing the template of the bcf2000 in mackie mode? mountain utilities shows jsut empty presets.
The BCF2000's behavior in its emulation modes is hard-coded in the firmware, so you can't change this behavior (unless you rewrite the firmware, of course!).
The 32 presets simply don't apply in the emulation modes, which is why BC Manager doesn't allow you to send/receive presets if it has detected that the BCF is in an emulation mode.
> i'm asking because i would really want to add a few changes to the layout as it is a bit wrong in ableton live.
There are 4 different emulation modes. I'm not sure which one is the best for Live, but you might experiment a bit.
Hope this helps,
Mark.
