Any way to make a bcr2000 button act as a continuous controller?
2013-01-16 by Ron Anderson
2013-01-17 by Royce
--- In bc2000@yahoogroups.com, Ron Anderson wrote: > > Is is at all possible to to make a bcr2000 button act as a continuous controller? > Sure.... for Mod Wheel CC $button 33 ; .easypar CC 01 07 127 0 increment 1 .showvalue on .default 0 $end Repeated pressing of the button $B0 1 0 $B0 1 1 $B0 1 2 ... $B0 1 126 $B0 1 127 $B0 1 0 ... > I would like two or more greater than zero value midi messages from one click of a particular button for reasons that are just an experiment. > There are a few ways to do it. Here is one. For Mod Wheel and Volume on channel 1 $button 33 ; .showvalue on .incval 1 .minmax 10 6 .default 6 .tx $B0 1 val .tx $B0 7 val $end A few clicks $B0 1 6 $B0 7 6 $B0 1 7 $B0 7 7 $B0 1 8 $B0 7 8 $B0 1 9 $B0 7 9 $B0 1 10 $B0 7 10 $B0 1 6 $B0 7 6 All the best Royce
2013-01-17 by rinnmigiroeven
Is this possible with NRPNs as well? As for say the Akai Miniak? --- In bc2000@yahoogroups.com, "Royce" wrote:
> > > > --- In bc2000@yahoogroups.com, Ron Anderson wrote: > > > > Is is at all possible to to make a bcr2000 button act as a continuous controller? > > > Sure.... for Mod Wheel CC > > $button 33 ; > .easypar CC 01 07 127 0 increment 1 > .showvalue on > .default 0 > $end > > Repeated pressing of the button > > $B0 1 0 > $B0 1 1 > $B0 1 2 > ... > $B0 1 126 > $B0 1 127 > $B0 1 0 > ... > > > I would like two or more greater than zero value midi messages from one click of a particular button for reasons that are just an experiment. > > > There are a few ways to do it. Here is one. > For Mod Wheel and Volume on channel 1 > $button 33 ; > .showvalue on > .incval 1 > .minmax 10 6 > .default 6 > .tx $B0 1 val > .tx $B0 7 val > $end > > A few clicks > $B0 1 6 > $B0 7 6 > $B0 1 7 > $B0 7 7 > $B0 1 8 > $B0 7 8 > $B0 1 9 > $B0 7 9 > $B0 1 10 > $B0 7 10 > $B0 1 6 > $B0 7 6 > > All the best > Royce >
2013-01-17 by Royce
> Is this possible with NRPNs as well? As for say the Akai Miniak? Yes (don't know the Miniak NRPNs though) $button 33 ; .easypar NRPN 01 349 127 0 increment 1 ; 01 = channel, 349=14bit NRPN number ,127=max, 0 =min (both 14bit numbers) .showvalue on .default 0 $B0 $63 $02 $B0 $62 $5D $B0 $63 01 $B0 $63 $02 $B0 $62 $5D $B0 $63 02 $B0 $63 $02 $B0 $62 $5D $B0 $63 03 ... the same as the above but with 2 NRPN 349 and 350 $button 33 ; .showvalue on .incval 1 .minmax 127 0 .default 0 .tx $B0 $63 $02 .tx $B0 $62 $5D .tx $B0 $63 val .tx $B0 $63 $02 .tx $B0 $62 $5E .tx $B0 $63 val > > > Is is at all possible to to make a bcr2000 button act as a continuous controller? > > > > > Sure.... for Mod Wheel CC > > > > $button 33 ; > > .easypar CC 01 07 127 0 increment 1 > > .showvalue on > > .default 0 > > $end > > > > Repeated pressing of the button > > > > $B0 1 0 > > $B0 1 1 > > $B0 1 2 > > ... > > $B0 1 126 > > $B0 1 127 > > $B0 1 0 > > ... > > > > > I would like two or more greater than zero value midi messages from one click of a particular button for reasons that are just an experiment.
> > > > > There are a few ways to do it. Here is one. > > For Mod Wheel and Volume on channel 1 > > $button 33 ; > > .showvalue on > > .incval 1 > > .minmax 10 6 > > .default 6 > > .tx $B0 1 val > > .tx $B0 7 val > > $end > > > > A few clicks > > $B0 1 6 > > $B0 7 6 > > $B0 1 7 > > $B0 7 7 > > $B0 1 8 > > $B0 7 8 > > $B0 1 9 > > $B0 7 9 > > $B0 1 10 > > $B0 7 10 > > $B0 1 6 > > $B0 7 6 > > > > All the best > > Royce > > >
2013-01-18 by sghookings@tiscali.co.uk
Take a look at the template I made for Miniak/micron and placed either in files or in miniaktools files section. Load it into Mark's editor to see how I did it, or search them posts where psionic Royce and Mark helped me to do this. Worth looking on micron site form how Lipi dealt with negative nrpns. Regards Steve H >----Original Message---- >From: rpcfender@... >Date: 17/01/2013 22:53 >To: <bc2000@yahoogroups.com> >Subj: [bc2000] Re: Any way to make a bcr2000 button act as a continuous controller? > >> Is this possible with NRPNs as well? As for say the Akai Miniak? > >Yes (don't know the Miniak NRPNs though) > > $button 33 ; > .easypar NRPN 01 349 127 0 increment 1 ; 01 = channel, >349=14bit NRPN number ,127=max, 0 =min (both 14bit numbers) > .showvalue on > .default 0 > >$B0 $63 $02 >$B0 $62 $5D >$B0 $63 01 >$B0 $63 $02 >$B0 $62 $5D >$B0 $63 02 >$B0 $63 $02 >$B0 $62 $5D >$B0 $63 03 >... > > >the same as the above but with 2 NRPN 349 and 350 > > $button 33 ; > .showvalue on > .incval 1 > . minmax 127 0 > .default 0 > .tx $B0 $63 $02 > .tx $B0 $62 $5D > .tx $B0 $63 val >.tx $B0 $63 $02 > .tx $B0 $62 $5E > .tx $B0 $63 val > > >> > > Is is at all possible to to make a bcr2000 button act as a >continuous controller? >> > > >> > Sure.... for Mod Wheel CC >> > >> > $button 33 ; >> > .easypar CC 01 07 127 0 increment 1 >> > . showvalue on >> > .default 0 >> > $end >> > >> > Repeated pressing of the button >> > >> > $B0 1 0 >> > $B0 1 1 >> > $B0 1 2 >> > ... >> > $B0 1 126 >> > $B0 1 127 >> > $B0 1 0 >> > ... >> > >> > > I would like two or more greater than zero value midi messages >from one click of a particular button for reasons that are just an >experiment. >> > > >> > There are a few ways to do it. Here is one. >> > For Mod Wheel and Volume on channel 1 >> > $button 33 ; >> > .showvalue on >> > .incval 1 >> > .minmax 10 6 >> > .default 6 >> > .tx $B0 1 val
>> > .tx $B0 7 val >> > $end >> > >> > A few clicks >> > $B0 1 6 >> > $B0 7 6 >> > $B0 1 7 >> > $B0 7 7 >> > $B0 1 8 >> > $B0 7 8 >> > $B0 1 9 >> > $B0 7 9 >> > $B0 1 10 >> > $B0 7 10 >> > $B0 1 6 >> > $B0 7 6 >> > >> > All the best >> > Royce >> > >> > > >
2013-01-19 by Ron Anderson
Thanks everyone.
Hold my beer, I'm gonna try somthin'
--- On Fri, 1/18/13, sghookings@... <sghookings@...> wrote:
Subject: Re: [bc2000] Re: Any way to make a bcr2000 button act as a continuous controller?
To: bc2000@yahoogroups.com
Date: Friday, January 18, 2013, 6:54 AM
Steve H
>From:
rpcfender@...
>To:
NRPNs though)
> $button 33 ;
> .showvalue on
> .default 0
>$B0 $63 $02
>$B0 $62 $5D
>$B0 $63 01
>$B0 $63 $02
>$B0 $62 $5D
>$B0 $63 02
>$B0 $63
$02
>$B0 $62 $5D
>$B0 $63 03
NRPN 349 and 350
> $button 33 ;
> .showvalue on
> .incval 1
minmax 127 0
> .default 0
> .tx $B0 $63 $02
> .tx $B0 $62 $5D
> .tx
$B0 $63 val
>.tx $B0 $63 $02
> .tx $B0 $62 $5E
> .tx $B0 $63 val
$button 33 ;
showvalue on
>> > .default 0
>> > $end
the button
>> > $B0 1 0
>> > $B0 1 1
>> > $B0 1 2
>> > $B0 1 126
>> > $B0 1 127
>> > $B0 1 0
>> > > I
>from one
>experiment.
>> > For Mod
>> > $button 33 ;
>> > .showvalue on
>> > .incval 1
>> > .minmax 10 6
>> > .default 6
>> > .tx $B0 1
val>> > .tx $B0 7 val >> > $end >> > >> > A few clicks >> > $B0 1 6 >> > $B0 7 6 >> > $B0 1 7 >> > $B0 7 7 >> > $B0 1 8 >> > $B0 7 8 >> > $B0 1 9 >> > $B0 7 9 >> > $B0 1 10 >> > $B0 7 10 >> > $B0 1 6 >> > $B0 7 6 >> > >> > All the best >> > Royce >> > >> > > >
