--- In bc2000@yahoogroups.com, "Royce" <rpcfender@...> wrote:
> The birdie editor is not really suitable for sysex.
> You need Mark's editor and his notes on the Behringer Control Language (BCL) is you need to go this way.
> I would not go down this path as the Avid guys have made it easy for you by using the CC messages for the Venom.
> If you want to use LEARN on the BCR you are much better off not using an editor at all and just twisting the knob on the Venom or the Vyzex editor and letting the BC listen and learn from the CC messages sent out.
> If there is a special reason to use sysex then let me know, but as it stands this is not the way to make your template
> All the best
> Royce
> --- In bc2000@yahoogroups.com, "alberrobles_18" <alberrobles_18@> wrote:
> > Im using birdie editor for making my own venom synth template using the Learned function where you can input midi data for a specific encoder.
> > Right now im using a sysex message from venom editor for the filter cutoff (i know i can program this parameter using other ways but im testing if this can be done this way for using it with another parameters) which is
> > F0 00 01 05 21 00 02 09 00 6A 00 2A F7.
> > But birdie´s example comes as follows
> > $F0 $41 $36 $00 $24 $20 $01 $1C val $F7.
> > Im trying to match this two but i dont know how.
> > Im sending over and over using midi ox
> > $F0 $00 $01 $05 $21 $00 $02 $09 $00 $6A $00 value $F7 (and all sorts of variations)
> > The bcr responds, i know because the lights blink
> > in a circle but the encoder doesnt get the message.
> > Maybe someone can tell me what if im not dissecting the sysex message properly or if it is a sending method problem.
> > Heres a link to the manual with the sysex specs:
> > http://www.maudio.com/images/global/manuals/Venom%20User%20Guide_EN.pdf
> > Help!!
Thanks again Royce. Maybe im not been clear enough with what i want.
The deal is i want to use the bcr in standalone mode for patch creation using all posible parameters from the vyzex editor but i cant get the bc learn from it. I go usb mode and twist a knob it says good but the encoder doesnt get it. thats why i went sysex with it.
Now question: is it posible to learn in usb mode and then switching on the same preset to standalone for editing? recording in usb stays usb or can i switch?
The way i go is setting in the editor midi in port VENOM MIDI IN and in out port BCR2000 i twist it recognizes it but i doesnt get recorded on the knob.
Ill keep trying and ask on the m audio forums or something cause im not really sure if theres and impediment from the editor to do this, otherwise ill stick to the available parameters on cc implementation chart.
