No worries,
Sorry, scrap that. There is no modules folder in BCN44 Manager. Also by looking at the site it doesn't have the same red button for sysex in the edit page like BC manager, so it appears it doesn't control sysex parameters.
You'll need to try it with NRPN if the parameter doesn't have a CC number associated with it and if it has neither, then your out of luck :(
Buy a BCR2000, you won't regret it!
On Wednesday, 1 April 2015, 21:59, "rogersned26@... [bc2000]" <bc2000@yahoogroups.com> wrote:
Yes, thats because there is a configuration file already loaded for that synth/module in BC manager module folder in Program Files on your C: drive.
I had a look at the manual for BCN44 and it didn't specifically list control by sysex, but I can't imagine why it wouldn't as its basically a stripped down BCR2000 without USB.
See if you can load the AN200 config file into the modules folder on C:Drive for BCN44 and read it from the editor
If not don't worry, just use the learn function to map the relevant CC data to the appropriate encoder or use the NRPN to control it as it DEFINITELY supports those, plus they usually have better resolution (14-bit or 0-16000 instead of 7-bit or 0-127)
Besides you don't really want to control the AN200 via sysex if there is a CC option as its is VERY data heavy and will be much S L O W E R.
TIP-----> only use sysex when there is no CC option. #yiv7175372310 #yiv7175372310 -- #yiv7175372310ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv7175372310 #yiv7175372310ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv7175372310 #yiv7175372310ygrp-mkp #yiv7175372310hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv7175372310 #yiv7175372310ygrp-mkp #yiv7175372310ads {margin-bottom:10px;}#yiv7175372310 #yiv7175372310ygrp-mkp .yiv7175372310ad {padding:0 0;}#yiv7175372310 #yiv7175372310ygrp-mkp .yiv7175372310ad p {margin:0;}#yiv7175372310 #yiv7175372310ygrp-mkp .yiv7175372310ad a {color:#0000ff;text-decoration:none;}#yiv7175372310 #yiv7175372310ygrp-sponsor #yiv7175372310ygrp-lc {font-family:Arial;}#yiv7175372310 #yiv7175372310ygrp-sponsor #yiv7175372310ygrp-lc #yiv7175372310hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv7175372310 #yiv7175372310ygrp-sponsor #yiv7175372310ygrp-lc .yiv7175372310ad {margin-bottom:10px;padding:0 0;}#yiv7175372310 #yiv7175372310actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv7175372310 #yiv7175372310activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv7175372310 #yiv7175372310activity span {font-weight:700;}#yiv7175372310 #yiv7175372310activity span:first-child {text-transform:uppercase;}#yiv7175372310 #yiv7175372310activity span a {color:#5085b6;text-decoration:none;}#yiv7175372310 #yiv7175372310activity span span {color:#ff7900;}#yiv7175372310 #yiv7175372310activity span .yiv7175372310underline {text-decoration:underline;}#yiv7175372310 .yiv7175372310attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv7175372310 .yiv7175372310attach div a {text-decoration:none;}#yiv7175372310 .yiv7175372310attach img {border:none;padding-right:5px;}#yiv7175372310 .yiv7175372310attach label {display:block;margin-bottom:5px;}#yiv7175372310 .yiv7175372310attach label a {text-decoration:none;}#yiv7175372310 blockquote {margin:0 0 0 4px;}#yiv7175372310 .yiv7175372310bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv7175372310 .yiv7175372310bold a {text-decoration:none;}#yiv7175372310 dd.yiv7175372310last p a {font-family:Verdana;font-weight:700;}#yiv7175372310 dd.yiv7175372310last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv7175372310 dd.yiv7175372310last p span.yiv7175372310yshortcuts {margin-right:0;}#yiv7175372310 div.yiv7175372310attach-table div div a {text-decoration:none;}#yiv7175372310 div.yiv7175372310attach-table {width:400px;}#yiv7175372310 div.yiv7175372310file-title a, #yiv7175372310 div.yiv7175372310file-title a:active, #yiv7175372310 div.yiv7175372310file-title a:hover, #yiv7175372310 div.yiv7175372310file-title a:visited {text-decoration:none;}#yiv7175372310 div.yiv7175372310photo-title a, #yiv7175372310 div.yiv7175372310photo-title a:active, #yiv7175372310 div.yiv7175372310photo-title a:hover, #yiv7175372310 div.yiv7175372310photo-title a:visited {text-decoration:none;}#yiv7175372310 div#yiv7175372310ygrp-mlmsg #yiv7175372310ygrp-msg p a span.yiv7175372310yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv7175372310 .yiv7175372310green {color:#628c2a;}#yiv7175372310 .yiv7175372310MsoNormal {margin:0 0 0 0;}#yiv7175372310 o {font-size:0;}#yiv7175372310 #yiv7175372310photos div {float:left;width:72px;}#yiv7175372310 #yiv7175372310photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv7175372310 #yiv7175372310photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv7175372310 #yiv7175372310reco-category {font-size:77%;}#yiv7175372310 #yiv7175372310reco-desc {font-size:77%;}#yiv7175372310 .yiv7175372310replbq {margin:4px;}#yiv7175372310 #yiv7175372310ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv7175372310 #yiv7175372310ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv7175372310 #yiv7175372310ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv7175372310 #yiv7175372310ygrp-mlmsg select, #yiv7175372310 input, #yiv7175372310 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv7175372310 #yiv7175372310ygrp-mlmsg pre, #yiv7175372310 code {font:115% monospace;}#yiv7175372310 #yiv7175372310ygrp-mlmsg * {line-height:1.22em;}#yiv7175372310 #yiv7175372310ygrp-mlmsg #yiv7175372310logo {padding-bottom:10px;}#yiv7175372310 #yiv7175372310ygrp-msg p a {font-family:Verdana;}#yiv7175372310 #yiv7175372310ygrp-msg p#yiv7175372310attach-count span {color:#1E66AE;font-weight:700;}#yiv7175372310 #yiv7175372310ygrp-reco #yiv7175372310reco-head {color:#ff7900;font-weight:700;}#yiv7175372310 #yiv7175372310ygrp-reco {margin-bottom:20px;padding:0px;}#yiv7175372310 #yiv7175372310ygrp-sponsor #yiv7175372310ov li a {font-size:130%;text-decoration:none;}#yiv7175372310 #yiv7175372310ygrp-sponsor #yiv7175372310ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv7175372310 #yiv7175372310ygrp-sponsor #yiv7175372310ov ul {margin:0;padding:0 0 0 8px;}#yiv7175372310 #yiv7175372310ygrp-text {font-family:Georgia;}#yiv7175372310 #yiv7175372310ygrp-text p {margin:0 0 1em 0;}#yiv7175372310 #yiv7175372310ygrp-text tt {font-size:120%;}#yiv7175372310 #yiv7175372310ygrp-vital ul li:last-child {border-right:none !important;}#yiv7175372310
