Hi, I am a new BCR-2000 user. I will be using to control my Korg DW-8000 and my Roland JD-990. I have no issue controlling parameters in both of my synths. But when I change a patch from the synth, the location of each parameter is not being loaded in the BCR-2000. I do have the midi out of the synth going to the midi in of the BCR and they are using the same midi channel. I do not know if there is any setting in the BCR-2000 that will take care of this issue. Thanks in advance.
To keep the BC in sync with the synth you need to send the new values from the synth back to the BC.
While this is possible http://www.bwalk.com.au/DW6K/DW6k.html you need something in between the BC and the synth, usually a computer or a microcontroller.
Ah, thanks (be it somewhat late) for this answer, Royce. I thought I was going crazy and started thinking about 'fixing' the midi out on my DW-8000 after a lot of troubleshooting and googling. I'll try looking for a good microcontroller, as I'm not a big fan of inserting computers in my midi chains.
