Global Variables
Global Variables
2007-11-29 by abhunkin
Royce (especially) -
When not specifying .init in globals under $preset, I assume there
should not be listed any other globals (with the possible exception
of .name) when the intention is a preset "overlay" - that is, not
modifying any settings except the controls specified following. This
way the "basic" preset globals still apply.
Conversely, I assume that specifying .init does not reset other globals
to some default values. Rather that all usual global variables need to
be specified, as one cannot know what they may have been previously set
to.
Are these assumptions correct?
Re: Global Variables
Sorry - in the previous post, I should not have used the
term "global" variables; the variables are those listed under $preset
only. Actual "global" settings are not involved.
Art Hunkins
This
globals
to
set
> to.
2007-11-30 by rpcfender
Art
I'll call them preset general parameters (as you corrected in a later post).
As Mark pointed out in his excellent guide if you don't use a parameter the BC sets it for you.
So send
$preset
.name' Just a test"
.snapshot on
.request on
.egroups 2
.fkeys off
.lock on
.tx $F0 $41 $13 12 $F7
.init
and you'll get back the same values,
but if you now send (worst case)
$preset
you'll get back
$preset
.name ' '
.snapshot off
.request off
.egroups 4
.fkeys on
.lock off
.init
All the parameters are reset.
Any parameters you sent along with $preset are , of course, set correctly but the others are reset.
> to.
So even if you don't use .init all the values you don't send are reset to the BC's default values.
A bit of an unexpected trap there.
All the best
Royce
2007-11-30 by abhunkin
Thanks for this info, Royce. Your observations rule out the
possibility of any "overlay" preset - one that keeps values from the
previous preset except for buttons/encoders etc. newly programmed.
It also means that .init is superfluous.
In any case, it's useful to know what the defaults are. It could save
quite a bit of typing.
Art Hunkins
--- In bc2000@yahoogroups.com, "rpcfender" <rpcfender@...> wrote:
> Art
exception
This
later
> post).
parameter
> So send
> $preset
> .name' Just a test"
> .snapshot on
> .request on
> .egroups 2
> .fkeys off
> .lock on
> .init
> $preset
> you'll get back
> $preset
> .name '                          '
> .snapshot off
> .request off
> .egroups 4
> .fkeys on
> .lock off
> .init
> globals
need to
previously
> set
> > to.
reset
> All the best
> Royce
