BCR2000 Recognition...
2008-04-02 by warminstrel
Have installed all BC Drivers etc but for some reason BCR2000 is listed
as 'USB Audio Device' (this on Midi-Ox and Live).
Could this be why Mackie emu is not working as it should?
Anyone else getting same results?
Re: BCR2000 Recognition...
2008-04-02 by meefchaloin
i think if you run it on usb that is the default name, im just getting
set up & also have a usb keyboard which comes up as USB Audio Device
(2), which can get confusing. I dont know if there's any way of
changing the name but its normal behaviour, from the little experience
i have
Re: [bc2000] Re: BCR2000 Recognition...
2008-04-03 by Karl Lurman
Mac lets you rename midi devices and even assign different icons to
them... Luxury my friends, luxury...
Karl
>  i have
2008-04-03 by warminstrel
Thanks for the replys!
I have since found many references to XP recognising the BCR as 'USB
Audio Device'
I initialy thought this was an error because Live (or Reason for that
matter) will not converse with the BCR. Now I know that being listed
as 'USB Audio Device' is all ok it still does not answer why it will
not work?
Global is set to U-1. All midi settings in live as they should be but
will not communicate, at all (on any preset).
Have sys-ex-ed tha factory presets using midi-ox, still not working.
All started goin pete tong when tried to instal MCU. Since then
nothing has worked and Live has even stated to crash when I'm in the
midi section of preferecnes. Live has NEVER crashed before.
Anyone have an idea of what to do as I've read all thats in the
manuals several times.
I will add that I had also installed a BCR driver from the Behringer
site at about the same time as I tried to set up the MCU, anyone
found the BCR drivers cause a problem?
> Karl
getting
Device
experience
> >  i have
