Cgs synth
Gain Cell
Gain Cell
2015-07-19 by neilbaldwin70
http://www.cgs.synth.net/modules/cgs108_vca.html
I've built a couple of these to add CV amps to an existing project but am having trouble getting them to behave. Some things to note:
- they're running off 15V so I'm wondering if there are some resistor changes required?
- I had to substitue a couple of capacitors as I didn't have exactly the right values and they didn't appear to be that critical based on my loose understanding of this circuit: the 5pF on the board I changed for a 4.7pF and the 220n required on the input when wiring up I substituted with a 100n
With a 5V peak sine wave input I'm getting horrible distortion. My latest idea was to install a 50K trimmer instead of the 100K fixed resistor on the CV input wiring to see if I could dial in a resistance value that would work better but that's no been particularly successful.
Neil
Re: Gain Cell
2015-07-19 by Ken Stone
4.7 instead of 5 pf can be ignored. 100n instead of 220n will cut your bass response.
It is ESSENTIAL that there be a pulldown resistor on the CV input e.g.: a 100k to 5k6 voltage divider is needed between your CV and the gain cells CV input.
On Sun, Jul 19, 2015 at 8:16 PM, neil.a.Baldwin@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Neil
Ken Stone otherunicorn@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Re: Gain Cell
2015-07-20 by Neil Baldwin
Thanks Ken
With +/- 12V voltage to the CV voltage divider part I'm seeing about -0.6 to +0.6 V at the CV pin which is correct.
However, with no input signal to Input, turning up the gain pot eventually results in horrendous feedback-type output.
Neil
On 19 July 2015 at 11:34, Ken Stone otherunicorn@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Neil
Re: Gain Cell
2015-07-20 by Ken Stone
You probably need more decoupling on the power pins to the cells. These cells have huge gain.
On Mon, Jul 20, 2015 at 7:00 PM, Neil Baldwin neil.a.Baldwin@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Thanks Ken
Neil
Neil
Re: Gain Cell
So try swapping out the two 10n caps for something else?
Also I've notice that with the CV disconnected and, for example, a 5V sine wave connected to the input, the gain at the output stage is massive. Should you see unity gain with no CV applied?
On 20 July 2015 at 10:47, Ken Stone otherunicorn@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Thanks Ken
Neil
Neil
Re: Gain Cell
Leave the 10n there, and add a couple 100n on the main board (it's stripboard, isn't it?)
Adding a 100k trimmer wired b/w the rails via 100k (or greater) to the CV input will let you trim it to unity. It seems to vary a little, dependent on the transistors used.
On Mon, Jul 20, 2015 at 8:40 PM, Neil Baldwin neil.a.Baldwin@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Thanks Ken
Neil
Neil
Re: Gain Cell
Getting somewhere now, cheers Ken.
Incidentally, if you wanted to decrease the amount of available gain, would it just be a relatively simple mod?
On 20 July 2015 at 11:44, Ken Stone otherunicorn@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Thanks Ken
Neil
Neil
Re: Gain Cell
To decrease the available gain, reduce the value of the CV pull-down, or reduce the value of the feedback resistor between pins 5 and 6 of the cell.
Ken
On Tue, Jul 21, 2015 at 1:12 AM, Neil Baldwin neil.a.Baldwin@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Thanks Ken
Neil
Neil
Re: Gain Cell
2015-07-22 by Neil Baldwin
Thanks Ken.
On one of the gain cells, the output breaks up quicker than the other. I matched the NPNs as suggested but it doesn't make any difference. If I turn the gain pot up, at a certain point (just past midway if it matters) suddenly there is an inaudible load on the output. Here's a photo of it hooked up to my oscilloscope. If I then turn the pot further both the frequency and amplitude changes (of course). The initial appearance of this is not gradual but jumps in quite alarmingly. The other gain cell has a much more gradual breakdown at high gain.
Any ideas?
Here's a Dropbox link to a picture from the scope:
Neil
On 20 July 2015 at 23:29, Ken Stone otherunicorn@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Ken
Thanks Ken
Neil
Neil
Re: Gain Cell
2015-07-22 by Ken Stone
Sorry, I have no idea what's causing that. Maybe read up on Blackmer cells.
On Thu, Jul 23, 2015 at 4:24 AM, Neil Baldwin neil.a.Baldwin@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Thanks Ken.
Any ideas?
Neil
Ken
Thanks Ken
Neil
Neil
Re: Gain Cell
2015-07-23 by ghpicard
It looks like an HF oscillation. You could try enhancing the decoupling of the power supply input. Ceramic 10nF capacitors between the power legs of the ICs (+ and -) and ground can help. They must be soldered directly on the pins to avoid spurious inductance. Also, try not to route the output wires near the input section.
HTH
Re: Gain Cell
2015-07-24 by Neil Baldwin
Thanks for the tip. Unfortunately it has little to no effect.
I've practically rebuilt that cell from scratch now, even matched the other transistor pair. I'm wondering if it's being adversely affected by other circuits around it though the fact that I've got two identical gain cells built onto a piece of strip board in the same M-class module would suggest that's not the case.
For reference, the M-class module is a custom one that I made for a client (his scheme, my design) which includes:
CGS96 Triple Comparator
CGS84 Peaks and Troughs
CGS90 Phaser
CGS60 Stompbox Adapter
The gain cells are to replace the input parts of the CGS60 to give more gain and CV control so I'm only using the output side of that circuit.
On 23 July 2015 at 19:50, ghpicard@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
HTH
Re: Gain Cell
I hooked up the scope again and this time turned up the gain to max. The interference is a square-ish wave that decreases in pitch as you increase the gain (and vice versa). Seems to kick in at the crossover point between -ve and +gain
CGS90 Phaser
HTH
Re: Gain Cell
And a short video with audio. You can see/hear as I increase the gain from 0 up to (nearly) max and back down again.
CGS90 Phaser
HTH
Re: Gain Cell
2015-07-29 by Richard Brewster
I just built six of these for two Serge VCFQ modules. I am getting approximately unity gain with the test circuit with a 5K6 to ground on the CV input and the CV pot disconnected. My problem is a high frequency parasitic oscillation on a portion of the negative excursion of the output signal. All six behave the same. Thinking it has to do with my test breadboard, I added .1uf bypass caps near the power pins to the Gain Cell board. That didn't make any difference. When I added an external 47pf cap from OUT to FB in parallel with the 5pf on the board, I saw a reduction in the width of the parasitic, but it was still there. I also swapped in a TL072ACP for the LF353. Looked the same. Any ideas? I'm running on +/- 15V. Should I try a feedback cap larger than 47pf?
Richard Brewster
http://pugix.com
CGS90 Phaser
HTH
Re: Gain Cell
2015-07-29 by neilbaldwin70
Exactly what I'm getting Richard though oddly only in one of two I'm using on the same build.
A solution to this would be an enormous relief: this has spent about 3 solid days on my bench and I don't seem to be able to do anything to alleviate the noise.
On 29 Jul 2015, at 19:48, Richard Brewster pugix@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Richard Brewster
http://pugix.com
CGS90 Phaser
HTH
Re: Gain Cell
2015-07-30 by Richard Brewster
I think I've solved my problem. The input level was too high. I put a pot between the VCO output I am using and the input to the gain cell. Lowering the input level made the parasitic oscillation disappear.
Richard
Richard Brewster
http://pugix.com
CGS90 Phaser
HTH
Re: Gain Cell
2015-07-30 by neilbaldwin70
Interesting. My problem one will produce the oscillation with no input.
On 30 Jul 2015, at 03:03, Richard Brewster pugix@... [cgs_synth] <cgs_synth@yahoogroups.com> wrote:
Richard
Richard Brewster
http://pugix.com
CGS90 Phaser
HTH
