Crumar Musical Instruments User Group. group photo
Index last updated: 2026-04-28 23:17 UTC
bit99 - high pitch sound on low oct
2010-11-15 by PLASTICCUP
hi everyone!
recently i purchased a white bit 99 (+ white case) for cheap, that looks like brand new!
even the patch cards are still attached!
what i noticed first, was this high pitched, somewhat metalic sound, audible on lower octaves, if the filter is open. anyone else noticed this? is this a characteristic of the bit, or could it be a faulty chip or something like that? thanks!
mike
Re: [crumar] bit99 - high pitch sound on low oct
2010-11-16 by Michael Ashton
I think what you're referring to is characteristic of the Bit. If it9;s the same "whine" I'm thinking of, it is for me one of the Bit's most unique and endearing qualities. :)
As an aside, the Bit doesn't always sound very special by itself, but like many great instruments, if you get it into the right place in a mix, it's a secret weapon. I think the oscillators are the main reason. That whine -- which I think is possibly aliasing of some sort, never worked it out for certain -- gives basslines a certain edge and grit.
--mpa
On Mon, Nov 15, 2010 at 1:57 AM, PLASTICCUP <msurovka@...> wrote:
hi everyone!
mike
Quidquid latine dictum sit, altum viditur.
2010-11-17 by Michael Mehalshick
Hi Michael, Thanks for your response. The problem I am Having is not a high pitch noise, it is a small static burst after I play a note and it is only on 2 of the organ tones, it is possible that it could be a chip or possibly a capacitor. I will try subbing the chips on that one board to see if that cures the problem. Mike
Sent: Monday, November 15, 2010 8:40 PM
Subject: Re: [crumar] bit99 - high pitch sound on low oct
I think what you're referring to is characteristic of the Bit. If it's the same "whine" I'm thinking of, it is for me one of the Bit's most unique and endearing qualities. :)
--mpa
hi everyone!
mike
2010-11-18 by Michael Ashton
Is it happening on every voice, or only on a few? --Michael
On Wed, Nov 17, 2010 at 6:45 AM, Michael Mehalshick <mikem245@verizon.net> wrote:
--mpa
On Mon, Nov 15, 2010 at 1:57 AM, PLASTICCUP <msurovka@gmail.com> wrote:
hi everyone!
mike
2010-11-19 by Michael Mehalshick
Only two organ voices and one percussion
Sent: Thursday, November 18, 2010 1:19 AM
--mpa
hi everyone!
mike
