How to put E-SEQ files on a floppy using a TEAC USB UF000x external floppy drive and a Mac?
2017-07-30 by gianluca costamagna
2017-07-30 by Carol Beigel
The MX100A only sees ESEQ files on 720k diskettes. Maybe you might get lucky and be able to tape off the square opening on a 1.44 disk. To learn more about this, and how to convert MIDI to ESEQ, see www.midiplayertools.com Your best bet is to use Bluetooth, so see www.midiplayertools.com/Connecting.htm for all the details. The MD BT01 works on any old system with both a MIDI IN port and MIDI OUT port. Carol Beigel Sent from my iPhone
> On Jul 30, 2017, at 11:34 AM, gianluca costamagna gianlucacostamagna69@gmail.com [disklavier] <disklavier@yahoogroups.com> wrote: > > > > Hi everybody. I just bought an upright MX100A, and I'd like to add midi files found on the internet and put them on floppy disc. > I have a Mac running MacOS Sierra 10.12.5, an external TEAC USB UF000x floppy drive and some TDK MF2DD floppy discs. > My computer does not recognize the discs, and seems not to be able to format them. > Maybe I need the mac driver for the external TEAC drive: where can I find it? > Which is the right format for the floppies to be used on my disklavier? Is it right that MX100A uses E-SEQ files? > > Thank you. > Gianluca > > >
2017-07-30 by Mark Fontana
�GianlucaMy computer does not recognize the discs, and seems not to be able to format them.Hi everybody. I just bought an upright MX100A, and I'd like to add midi files found on the internet and put them on floppy disc.I have a Mac running MacOS Sierra 10.12.5, an external TEAC USB UF000x floppy drive and some TDK MF2DD floppy discs.
Maybe I need the mac driver for the external TEAC drive: where can I find it?Which is the right format for the floppies to be used on my disklavier? Is it right that MX100A uses E-SEQ files?
Thank you.
