Midi files on CDs?
Midi files on CDs?
2004-12-23 by sjhart110110
Anyway to have my DC3A (Mark III) play midi files from a CD?  It
sure would be nice to burn files to CDs to play them.  Not sure why
Yamaha did not have this feature.  Certainly would save a lot of
diskettes!  Thanks for any info.  SJ
Re: [disklavier] Midi files on CDs?
2004-12-24 by James Fry
As other people have said, at the time this would have probably cost a lot
of money to implement, and probably wasn't really considered necessary (a
complete performance will fit on a floppy easily). For longer playback
MIDI could be used.
It is possible to get MIDI players now that take flash cards, and they
don't cost an arm and a leg. With a cheap (ie $10) card reader/writer you
could transfer midi files to a card (say 256MB) and have one hell of a lot
of music available!
James
Re: Midi files on CDs?
2004-12-24 by xxmistert0xx
This is a strange shortcoming of such a device.  Given that the
floppy drive has the ability to allow you to use MIDI files I don't
understand how much more it would have taken to add the same ability
via CD.
I did find a utility that will convert MIDI to WAV and then of course
you can create a CD from that, but that's hardly anything to compare
using the actual MIDI files.
why
cost a lot
necessary (a
playback
> MIDI could be used.
they
reader/writer you
of a lot
> of music available!
> Regards,
> James
2004-12-26 by sjhart110110
I agree.  Also, the wave files created by the utility are much too
large.
I can't see how this would be that big of a deal for Yamaha to add
in a firmware upgrade.  It would be OK to add a few limitations if
needed (e.g. only can play 99 songs if the display can't handle
anything past this).
I had to store the recent piano e-comp on many many diskettes.  I
could have put the entire competition on one CD!  I would think this
would be even better for folks with pro models.
I do have my laptop connected to my DC3A and do use playlists, etc.
However, I don't like to have to turn on the laptop all of the time.
Yamaha, PLEASE add midi CD support to Mark IIIs!  Thanks.
--- In disklavier@yahoogroups.com, "xxmistert0xx"
don't
ability
> via CD.
course
compare
It
sure
> why
of
> cost a lot
> necessary (a
> playback
> > MIDI could be used.
and
> they
> reader/writer you
hell
> of a lot
> > of music available!
> > Regards,
> > James
