Disklavier intermittent with MIDI output
2008-08-25 by slothmachine
Hi all,
I recently had a recording session that used a Disklavier.  We needed
to record the actual piano sounds as well as get the corresponding
MIDI.  For the most part, it worked well.  Our resulting audio files
are great, and the corresponding MIDI almost always matches
perfectly.  There were a few exceptions though.  In a few of the
files, the MIDI would cut out for almost exactly 30 seconds, then
after that silence, it would return, still in sync with the audio.
There are a few possible explanations for this.  It's certainly
possible that the MIDI interface going into the computer was faulty
in some way (audio and MIDI both recorded into Reaper).  Me feeling
though is that it was probably something getting stuck on the
Disklavier's end.  The exact devices were Disklavier II, and the
controller that spit out the MIDI was a DKC100R.
Has anyone else had similar issues?  Any suggestions for how to fix
this?  We're planning on going back to the same studio, with the same
setup, in a few days, so we were hoping to have something new to try.
I did try searching previous posts for "lost MIDI", but wasn't able
to find anything pertinent.
Any help would be greatly appreciated.  Thanks very much!
Re: [disklavier] Disklavier intermittent with MIDI output
2008-08-26 by athomik
I would think there are 2 possibilities.
1. there could be an intermittent MIDI connection. This could be the cables, the sockets these plug into or the interface.
2. you may have a problem with the key/hammer sensors. If you try to record again, put the piano into record mode as well. If the piano plays the recording back OK, it's your connections/interface, if the playback on the piano is intermittent, you have a problem with your sensors.
athomik
On Aug 26 2008, slothmachine wrote:
>Hi all,
2008-08-26 by George F. Litterst
Good morning, everyone.
I recommend looking at the MIDI data carefully on the computer and
determine with certainty whether that MIDI data is present.
Assuming that the MIDI data is present, I think that it is worth
determining:
--whether the dropouts always occur at the same places on playback
--determine what happens if you start playback at a location where
there is a dropout
--look at the MIDI status LEDs on the MIDI interface (if there are
any) during playback and see if the interface shows MIDI data going to
the piano during the dropout
How are you synchronizing the audio and the data? Are they both being
played by the same sequencer?
PianoBench
On Aug 25, 2008, at 7:00 PM, slothmachine wrote:
> Hi all,
Re: Disklavier intermittent with MIDI output
2008-08-26 by slothmachine
Athomik & George,
Thank you very much for replying with such good suggestions.
Athomik, I think your suggestion is best to actually record on the
piano itself, in addition to sending it through the MIDI outputs.  I
think the reason we didn't do that the first time is that those
floppy disks don't hold that much information, so we would have ended
up continually replacing them.  We could be wrong though about how
much info they hold.  About how much time does one of those disks
hold?  (I know that with MIDI it's not time that takes the space, but
the number of notes played, but just assuming that he's playing some
normal piano music, how much time...)
George, to answer your questions, the dropouts don't always occur in
the same place, but they seem to almost always last for about 33
seconds.  This is kind of what made me rule out faulty cables,
because it would just be too much of a coincidence that cables would
fail, several times, each lasting 30 seconds.  The behaviour would
seem to me that it's some device along the way, whether it's the
piano sending to the DKC100R, the DKC100R sending to the MIDI
interface into the computer, or the MIDI interface into the computer,
that somehow gets overloaded with info and takes 30 seconds
to "restart" itself at which point it continues to spit out MIDI info.
The MIDI and audio both get recorded simultaneously into the
sequencer REAPER, and yes, we're certain that for those dropouts
there is no MIDI at all.  You just have to look at an event list to
see that there's nothing there.
Also George, as per your suggestion, I will instruct the engineer to
pay close attention to the flashing lights on the MIDI interface
while he records to make sure that that is being recorded correctly.
Thanks again for your help, I now have some very useful information
for when we go into the studio next.
Sincerely,
Tobin
--- In disklavier@yahoogroups.com, "George F. Litterst"
> determining:
> there is a dropout
to
being
> Regards,
> PianoBench
> > Hi all,
needed
faulty
same
try.
able
Re: [disklavier] Re: Disklavier intermittent with MIDI output
2008-08-26 by Spencer_Lists
Greetings slothmachine,
a couple of other possibilities to consider.
i have had systematic (seem random at first glance but have some sort of pattern) failure of MIDI interfaces occasionally. the MIDI spec says that a receiver of MIDI data should pass on anything that it can not process and get on with the rest. however it seems (no real proof of this but it has happened enough to suggest so) that some devices can choke on something they do not process properly, a sysex message possibly. they may recover or may need to be rebooted. for this reason, i have a few different interfaces (different brands and models) and when one just doesn't seems to work for some bizarre reason that i can not figure out, i just try another one. of course it could be something in the DKV firmware that does not come into play often enough to have been identified by other users. cyclical failures can be problems with data buffer management. if there is some strange bug in the firmware, changing a mode or setting might allow the firmware to operate differently and not hit the bug. try an update if there is one,
Best regards,
Spencer_Lists Chase        mailto:lists@...
67550 Bell Springs Rd.
Garberville,  CA 95542    Postal service only.
Laytonville, CA 95454    UPS only.
Lists@spencerserolls(dot)com
http://www(dot)spencerserolls.com
replace (dot) with a .
(707) 984-8356
Good afternoon, everyone.
I am a little confused, Tobin. On the one hand you indicated that the
dropouts on playback do not always occur in the same places each time
you play back a file. That tells me that all of the MIDI data is
present in the file. However, you also said that you checked the file
and saw no MIDI data in the event list where dropouts occur.
The first and most important thing is to figure out if data is being
continuously recorded during the performance. The event list should
confirm this. If the data for the entire piece is present, you should
be able to listen to the entire piece without dropouts by directing
the MIDI output of the sequencer to an internal tone generator on your
computer (QuickTime GM Synth on the Mac or Microsoft GS Wavetable SW
Synth on Windows). Playback by those 2 soft synths may be muddy
(because they don't understand incremental pedaling), but you will be
able to confirm aurally that all of the notes are there.
Assuming that all of the notes are there, there should be no droupouts
on playback by the piano. If there are, the most likely culprits are:
--sequencer
--the MIDI cables or interface
--the Disklavier
In the case of the Disklavier, overheating can cause playback
dropouts. However, consistent overheating usually results in an error
message on the control unit.
If you choose to record to high density floppy disks (formatted as
HD), you should be able to get 2 hours of normal piano playing on a
floppy (assuming that the piano is not a version called the Pro).
PianoBench
On Aug 26, 2008, at 11:26 AM, slothmachine wrote:
> Athomik & George,
> Sincerely,
> Tobin
> > determining:
> > there is a dropout
> to
> being
> > Regards,
> > PianoBench
> > > Hi all,
> needed
> faulty
> same
> try.
> able
Hi George,
A little confusion there:  We recorded about 30 separate files.  The
MIDI dropout occurs in about 15% of those files at different places
in each file (in other words, in one file it may occur 15 seconds
into the file, in another file it may occur 5 minutes into the file)
but in every case, the dropout lasts for 30 seconds.  In any one
given file where the dropout occurs, however, yes, obviously the
dropout occurs in the same place all the time.  MIDI data is
definitely not present during those dropouts.
That's excellent news that a floppy should be able to hold about 2
hours.  I think we're going to use that as a backup.  If we find that
we're experiencing dropouts again, we'll immediately check the floppy
to see if it also occurred on that.
Again, thanks for your help.
Tobin
time
file
being
should
should
directing
your
SW
be
droupouts
are:
> --sequencer
> --the Disklavier
error
a
> Regards,
> PianoBench
> > Athomik & George,
I
ended
but
some
in
would
computer,
info.
to
correctly.
information
> > Sincerely,
> > Tobin
and
> > > determining:
playback
where
> > > there is a dropout
are
going
> > to
> > being
> > > Regards,
> > > PianoBench
> > > > Hi all,
> > needed
corresponding
files
then
audio.
> > faulty
feeling
to fix
> > same
to
> > try.
> > able
2008-09-04 by George F. Litterst
Tobin, just checking: has everything been working correctly?
PianoBench
On Aug 26, 2008, at 5:02 PM, slothmachine wrote:
> Hi George,
> Tobin
> the
> time
> file
> being
> should
> should
> directing
> your
> SW
> be
> droupouts
> are:
> > --sequencer
> > --the Disklavier
> error
> a
> > Regards,
> > PianoBench
> > > Athomik & George,
> I
> ended
> but
> some
> in
> would
> computer,
> info.
> to
> correctly.
> information
> > > Sincerely,
> > > Tobin
> and
> > > > determining:
> playback
> where
> > > > there is a dropout
> are
> going
> > > to
> > > being
> > > > Regards,
> > > > PianoBench
> > > > > Hi all,
> > > needed
> corresponding
> files
> then
> audio.
> > > faulty
> feeling
> the
> to fix
> the
> > > same
> to
> > > try.
> > > able
2008-09-09 by slothmachine
Hi George,
Yes, we recorded again, and this time the problem went away for the
most part.  We didn't really do anything different, but it just
seemed to be behaving itself this time.  In about 3 hours of recorded
material, the MIDI only dropped out once, and I can live with that...
Thanks again for everyone's help with this issue.
Tobin
> Regards,
> PianoBench
> > Hi George,
places
file)
that
floppy
> > Tobin
that
> > the
> > time
> > file
> > being
> > should
> > should
> > directing
on
> > your
Wavetable
> > SW
will
> > be
> > droupouts
> > are:
> > > --sequencer
> > > --the Disklavier
> > error
as
on
> > a
Pro).
> > > Regards,
> > > PianoBench
> > > > Athomik & George,
on the
outputs.
> > I
those
have
> > ended
how
disks
space,
> > but
playing
> > some
occur
> > in
33
> > would
would
> > computer,
MIDI
> > info.
dropouts
list to
engineer
> > to
interface
> > correctly.
> > information
> > > > Sincerely,
> > > > Tobin
computer
> > and
worth
> > > > > determining:
> > playback
> > where
> > > > > there is a dropout
there
> > are
data
> > going
> > > > to
both
> > > > being
> > > > > Regards,
> > > > > PianoBench
> > > > > > Hi all,
Disklavier. We
> > > > needed
> > corresponding
audio
> > files
matches
of the
seconds,
> > then
> > audio.
certainly
was
> > > > faulty
> > feeling
and
> > the
how
> > to fix
with
> > the
> > > > same
new
> > to
> > > > try.
wasn't
> > > > able
