Re[2]: e-comp
Re[2]: e-comp
2008-09-28 by Spencer_Lists
Greetings Rick,
There are two things you can try to remap the channels. Find the files4download page of my web site. Two programs there could be of use. One is midimod2. It has been a long time since I used it and I might have broken it in some recent feature adding frenzy but it is the best candidate so give it a try. If you check the "piano parts to Ch. 1 and 2" checkbox and leave the preset at the default of "no change" and leave the other settings at the default values, it should move any events that have a piano voice definition to channel 1 if not there already and leave them on 2 if that is where they are. If the voices are assigned to a normal piano part (patch 0 through 7) they will be moved. If the parts are unassigned this will not work.
The other possibility is to change the channel of the pianos parts (once you identify what channel they are on) to channels 1 and 2 so the DKV will play them as piano. The "remap channels" program will do this but you need to know what channels to remap and can make a real mess if you do it wrong.
Let me know if you have success with either of these programs? I get very little feedback on them.
Sunday, September 28, 2008, 1:49:37 PM, you wrote:
> I can only speak for myself in that I would not have a need for the
> conversion to Mp3. I would hope others will let you know their desires.
> There is one thing that you might be able to help me with. I have
> downloaded many midi files that have the piano data on a different
> midi "channel" than what my Disklavier is set to play as the default
> channel. Is there a simple way to rearrange this information in the
> midi file so that the desired channel is outputted to the default
> piano channel? I just use VanBaskos to play to my earlier model
> Disklavier. Sorry if I don't have all of the jargon right.
> Thanks,
> Rick
> ____________________________________________________________
> Fashion Design Education - Click Here!
> http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3oIax39wF5rak1OHWE4wvfvuC3ypPcUXsnnap6SN9vmd8faQ/
Best regards,
Spencer_Lists Chase        mailto:lists@...
67550 Bell Springs Rd.
Garberville,  CA 95542    Postal service only.
Laytonville, CA 95454    UPS only.
Lists@spencerserolls(dot)com
http://www(dot)spencerserolls.com
replace (dot) with a .
(707) 984-8356
