Re[6]: [disklavier] computer-Disklavier nothing happens
2008-11-12 by Dokhanchi
Thank you for your help. But I don't think I am communicating my concerns properly. I need to be able to play these files from my Dell laptop on the Disklavier. The files work if I place them on a floppy, I just can't get them to work from my laptop to the piano. maybe I'm not using the right software, cables, or settings on the computer and disklavier. I have a Midi to usb cable that is connected properly. Also I use VanBasco's software to play them. Still no effect on the piano. Any help is truly appreciated. I have Mark III-B version (DGC1-B). --- On Mon, 11/10/08, Spencer_Lists <lists@...> wrote:
> From: Spencer_Lists <lists@...> > Subject: Re[6]: [disklavier] computer-Disklavier nothing happens > To: "Dokhanchi" <dokhanchi@...> > Date: Monday, November 10, 2008, 1:58 PM > Greetings Dokhanchi, > > here is a simple file that should work on the DKV. > > Sunday, November 9, 2008, 11:44:56 PM, you wrote: > > please do, I would appreciate it. Thanks. > > > > --- On Mon, 11/10/08, Spencer_Lists > <lists@...> wrote: > > >> From: Spencer_Lists > <lists@...> > >> Subject: Re[4]: [disklavier] computer-Disklavier > nothing happens > >> To: "Dokhanchi" > <dokhanchi@...> > >> Date: Monday, November 10, 2008, 1:41 AM > >> Greetings Dokhanchi, > >> > >> I looked very briefly at this file. Even thought > it is a > >> type 0 file, > >> it is quite complex with all sorts of events in > it. The DKV > >> really > >> wants a simple file. This is a multi part mess. I > would > >> start with a > >> simple piano solo MIDI file to make sure your > setup works > >> correctly > >> before trying something like this. I can send you > a sample > >> file to try > >> and then you may have to work on a file like this > to get it > >> to play. > >> Let me now if you want to start a systematic > approach to > >> diagnosing > >> your problem. > >> > >> Sunday, November 9, 2008, 10:14:44 AM, you wrote: > >> > Here is one of the files I have been testing. > I have a > >> bunch of > >> > other files also. The problem is not that > they > >> don't play on the > >> > disklavier, the problem is that I can not > play them > >> from my > >> > computer. They play fine when on a disk. > Thanks for > >> your help. > >> > >> > --- On Sun, 11/9/08, Spencer_Lists > >> <lists@...> wrote: > >> > From: Spencer_Lists > <lists@...> > >> > Subject: Re[2]: [disklavier] > computer-Disklavier > >> nothing happens > >> > To: "Dokhanchi" > >> <disklavier@yahoogroups.com> > >> > Date: Sunday, November 9, 2008, 12:04 PM > >> > >> > Greetings Dokhanchi, > >> > >> > I have a program that fixes some of the > things that > >> can cause a file > >> > to not play on the DKV. If you send me the > file that > >> you are having > >> > problems with, I might be able to suggest a > fix. > >> > >> > Sunday, November 9, 2008, 6:50:25 AM, you > wrote: > >> >> Hi PianoBench, > >> >> > >> >> Everything you said was done but I still > do not > >> get anything. Do I > >> >> need to have the disklavier's drive > on > >> something else to recognize > >> >> the data is coming from an external > source? It > >> almost feels like > >> >> something has to be turned on so the > Piano can > >> receive the data sent > >> >> by the cable. Once again I am using a USB > to midi > >> cable I bought > >> >> from Ebay. The laptop recognizes the > cable and > >> installs it once > >> >> plugged in. When I play the song in > VanBasco's > >> jukebox, the light on > >> >> the cable flashes showing the data is > going > >> through the cable but > >> >> does not seem to enter the piano at all. > Help > >> please. > >> >> > >> >> Bob > >> > >> >> --- On Fri, 11/7/08, George F. Litterst > >> <PianoBench@aol. com> wrote: > >> >> From: George F. Litterst > <PianoBench@aol. > >> com> > >> >> Subject: Re: [disklavier] > computer-Disklavier > >> nothing happens > >> >> To: disklavier@yahoogro ups.com > >> >> Date: Friday, November 7, 2008, 10:55 AM > >> > >> >> Good morning, everyone. > >> > >> >> Bob, there are a few things to check: > >> > >> >> (1) It is very easy to confuse which > plugs connect > >> to MIDI In and MIDI > >> >> Out. Try reversing them. (You won't > hurt > >> anything if you have > >> >> incorrectly reversed the connection.) > >> > >> >> (2) The Disklavier is both a piano and a > tone > >> generator. Certain > >> >> incoming MIDI tracks play on the piano, > and all > >> others are played by > >> >> the tone generator. If the speakers are > note > >> turned on, you will not > >> >> hear the other tracks. > >> > >> >> (3) To insure that your Disklavier plays > the > >> correct tracks on the > >> >> piano, you need to match the piano's > Receive > >> Channel(s) to the MIDI > >> >> channels to which the piano track(s) are > assigned > >> in the MIDI file. > >> >> Unfortunately, the piano tracks may be on > >> different channels in > >> >> different files. The simplest way to > account for > >> this is to let the > >> >> Disklavier guess (which it can do > correctly about > >> 95% of the time) and > >> >> set the piano's Receive Channel to > PRG(ALL). I > >> have not used the B > >> >> version of the Mark III. I am guessing > that you > >> make this selection in > >> >> the following way: > >> > >> >> --Press Function > >> >> --Use the Right Arrow button to select > MIDI Setup > >> and then press Enter > >> >> --With the cursor next to Piano Part, > press Enter > >> >> --The display will show you the current > Piano > >> Receive channel which > >> >> you can change with the +/- buttons. > >> > >> >> Regards, > >> >> PianoBench > >> > >> >> On Nov 7, 2008, at 11:42 AM, Dokhanchi > wrote: > >> > >> >>> I need help please with my Mark III B > version > >> (DGC1-B). I have used > >> >>> VanBascos's software per > carol's > >> recommendation and am using the USB- > >> >>> MIDI cable I bought from Ebay. The > ToHost > >> selector is set to midi > >> >>> and the cable powers up and > recognized by he > >> computer. When I play a > >> >>> song in vanbasco, the blue light on > the cable > >> flashes showing the > >> >>> data is going through the USB cable > into midi > >> in/out. The problem is > >> >>> I can not get the piano to play it. > When I > >> turn the disklavier on, > >> >>> it is still on the internal drives. > >> Doesn't have to be on an > >> >>> external midi selection? I can't > find such > >> selection. Any help is > >> >>> appreciated. > >> >>> > >> >>> Bob > >> >>> > >> >>> > >> > >> >> > >> > >> > >> -- > >> Best regards, > >> Spencer_Lists Chase > mailto:lists@... > >> 67550 Bell Springs Rd. > >> Garberville, CA 95542 Postal service only. > >> Laytonville, CA 95454 UPS only. > >> Lists@spencerserolls(dot)com > >> http://www(dot)spencerserolls.com > >> replace (dot) with a . > >> (707) 984-8356 > > -- > Best regards, > Spencer_Lists Chase mailto:lists@... > 67550 Bell Springs Rd. > Garberville, CA 95542 Postal service only. > Laytonville, CA 95454 UPS only. > Lists@spencerserolls(dot)com > http://www(dot)spencerserolls.com > replace (dot) with a . > (707) 984-8356
