Yamaha MPX70 in Silent mode
2010-01-01 by mjd7282
When I play my MPX70 in Silent mode, the basic piano sound is not at all bad, BUT the elderly processor appears unable to keep up with the number of notes being played (along with use of the sustaining pedal) on stride piano solos.  The result is that the sound of the notes can be delayed, with chords in particular being broken rather than sounding in unison.  Examples of the type of music which causes this problem can be found amongst my YouTube videos (my user ID is honkytonkpiano).  I suspect that the MPX70's sound generator simply doesn't have enough computer power, and that the only solution might be to acquire a separate sound generator unit to accept the MIDI out from the MPX70.  I would be grateful for suggestions (other than DON'T PLAY THAT TYPE OF MUSIC ANY MORE!!)
Thanks in anticipation,
Mike Thomson
Re: [disklavier] Yamaha MPX70 in Silent mode
2010-01-01 by Mark in Idaho
Mike,
Have you ever cleaned out/off the circuit board and such. Slowed
processing can be the result of over-heating and other dust bunny
related problems. A can of air might help. Unplug the piano before
trying to clean things off. Use the plastic straw that comes with the
can and blow off every part. Pay attention to the areas where an I/C
chip connects to the printed circuit board. Those little fingers can get
dust bridging across them. Clean out any vent holes you may have too.
Hope this helps.
Mark in Idaho
> Mike Thomson
2010-01-05 by athomik
As a default, the MPX70 has 32 note polyphony, so you're probably running out of notes. There should be a function where you can set the polyphony to 64 notes, although this will affect the sound quality slightly.
athomik
On Jan 1 2010, Mark in Idaho wrote:
>Mike,
>Hope this helps.
>Mark in Idaho
>> Mike Thomson
>To Post a message to the group, send it to: disklavier@...
>To Post a private message to Todd Muncy, the group's founder and moderator, send it to:
>disklavier-owner@...
>To reach our group's web site go to:
>http://Yahoogroups.com/group/disklavier
>THINKING OF LEAVING THE GROUP?
>If you are thinking of unsubcribing because you are getting too much mail, go the the web site and change your email delivery option instead. That will fix the problem, while maintaining your access to the group. If you insist on leaving us completely send a blank email to:
>disklavier-unsubscribe@...
>Know someone who wants to join? Have them send a blank email to:
>disklavier-subscribe@... or give them this link:
>http://Yahoogroups.com/group/disklavier/join
>Yahoo! Groups Links
><*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/disklavier/
><*> Your email settings:
> Individual Email | Traditional
><*> To change settings online go to:
> http://groups.yahoo.com/group/disklavier/join
> (Yahoo! ID required)
><*> To change settings via email:
> disklavier-digest@yahoogroups.com
> disklavier-fullfeatured@yahoogroups.com
><*> To unsubscribe from this group, send an email to:
> disklavier-unsubscribe@yahoogroups.com
><*> Your use of Yahoo! Groups is subject to:
