Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
Re: [elektron] Digest Number 1397
2004-11-10 by Robert Ryman
Greetings -
I am the owner of a Machine Drum and am inquiring as
to what I need to be able to record my creations using
my G4 Powerbook.  I am open to some sugguestions as to
what software and audio interfaces would work best
with my Powerbook.  However, I am curious as to if
investing in an audio interface and some software
would be the answer to my prayers.  Is another way to go?
Do you Yahoo!?
Check out the new Yahoo! Front Page.
www.yahoo.com
2004-11-10 by Scott Kellogg
It depends on what you want to do.  If you just want to record the MD
live into the Powerbook, you could get away with something like an
Indigo I/O (PCMCIA audio card), and free software, such as Audacity.
http://www.echoaudio.com/Products/CardBus/IndigoIO/index.php
http://audacity.sourceforge.net
Hope this helps.
/Scott
Robert Ryman wrote:
> Greetings -
> Do you Yahoo!?
> www.yahoo.com
Anyone doing this?
Do you Yahoo!?
www.yahoo.com
2004-11-10 by Federico Ciapi
> Hope this helps.
> /Scott
Don't buy the Indigo I/O, it doesn't work well on Al Powerbooks.
I tried two of them.
Get a firewire interface instead, there's a new presonus one which is
nice and compact.
Ah, didn't know that.
> nice and compact.
Yep, I've heard good things about this interface.  Might cost a little
more, though.
/Scott
2004-11-10 by Christopher Mitchell
I disagree.  I've got an Indigo I/O and an Al powerbook and it seems to
work fine.  Federico, what was the problem you had on the Al Book?
I'll try to duplicate it on mine.
Do hope I can buy another MOTU 828 Mk2 again pretty soon... (Sold it
before a move).  That is my i/o box of choice currently.  I don't
really have enough time to do any recording though for the moment.
Yours,
Chris
>> Hope this helps.
>> /Scott
> nice and compact.
[OT] Indigo I/O - was: Digest number 1397
Quite simply, sometimes it was recognised and worked fine, some others
it wasn't recognised and would hang the Powerbook.
I have one of the first Al PB 1.25ghz.
Echo support was really bad, suggesting me to install wrong drivers,
and many other kinds of BS.
Finally I had to change the card (the second one) with something else.
I think the problem was within the drivers because the log showed that
the card was recognised when inserted in the slot, but sometimes the
driver couldn't load properly.
Sound quality of the Indigo I/O is good anyway; and may be they have
fixed the problem I had, but are the latest drivers the old ones for
Jaguar?
If so, then it's not a good sign for a Mac user...
audio interface (was Digest Number 1397)
2004-11-10 by divi309
There are many options for you Robert. Check out the simple and cheap USB interfaces
like my Emagic A62m. They're perfect when you don't need loads of inputs. Firewire and
PCMCIA (like presonus, MOTU and RME) are much more pro, but also much more
expensive. On my wishlist is the firewire MOTU 828 mkII because I want maaaaaaaany I/
O's!
ciao dtr
--- In elektron-users@yahoogroups.com, Robert Ryman <rryman23@y...> wrote:
> Greetings -
> Do you Yahoo!?
> www.yahoo.com
2004-11-11 by endlessnessisticman
You don't really need to buy anything to record into the powerbook.
You might want to go to macmusic.org to get Line In and Audacity.
Just get a 1/8 input cord plug it into the powerbook.
wrote:
> Greetings -
> Do you Yahoo!?
> www.yahoo.com
Re: [elektron] [OT] Indigo I/O - was: Digest number 1397
2004-11-11 by Damon Menne
Just to pipe in, I'm using Panther on a Titanium 15" 1ghz PowerBook
with both an Echo Indigo DJ and an Echo Indigo I/O, and the both work
famously.  Great sound quality, great drivers, nice little mixer
console for the virtual outputs, low latency, couldn't be happier.
Might have been Jaguar?
>> to
> Jaguar?
